Deriving Lorentz transformation by light cone coordinates
In summary, deriving Lorentz transformation by light cone coordinates allows us to understand how objects in motion appear to observers in different frames of reference. Light cone coordinates are a way of representing space and time in special relativity and are used to derive Lorentz transformation. This method offers intuitive understanding and simplifies the mathematics involved, but it has limitations such as only working for objects at constant velocity and not being the only method to derive Lorentz transformation.
Whitehole
132
Derive the Lorentz Transformation using light cone coordinates defined by
##x^±=t±x##
##x^+ x^-~## is left invariant if we multiply ##~e^φ~## to ##~x^+~## and ##~e^{-φ}~## to ##~x^-~##, that is ##~x'^+ x'^-=x^+ x^-##
##t'^2 - x'^2 = t^2 - x^2 ~~~(invariance~of~spacetime~separation)##
##~x'^+ = e^φ x^+~## and ##~x'^- = e^{-φ} x^-##
Set ##~c = 1##
Since ##t'^2 - x'^2 = t^2 - x^2~##, we can set ##~x'^±=t'±x'~##
So that ##~t' = ½( x'^+ + x'^-) = ½( e^φ x^+ + e^{-φ} x^-) = t(coshφ) + x(sinhφ)~##
Similarly ##~x' = t(sinhφ) + x(coshφ)##.
Suppose ##~x' = 0~##, this implies ##~x = -ut~## then ##~u = \frac{sinhφ}{coshφ} = tanhφ##
From the identity ##~cosh^2φ - sinh^2φ = 1~##, we have ##~coshφ = \frac{1}{(1-u^2)^½}~## and ##~sinhφ = \frac{u}{(1-u^2)^½}~##.
Therefore,
##t' = \frac{t + ux}{(1-u^2)^½}##
##x' = \frac{x + ut}{(1-u^2)^½}##
Now to derive the inverse Lorentz transformation,
##~x^+ = e^{-φ} x'^+~## and ##~x^- = e^φ x'^-## (transferred ##e^φ## to the other side)
By using ##~x^±=t±x~##, we have ##~t = ½( x^+ + x^-) = ½( e^{-φ} x'^+ + e^φ x'^-) = ½( t'(e^{φ} + e^{-φ}) - x'(e^{φ} - e^{-φ})) = t'(coshφ) - x'(sinhφ)~##
Similarly ##~x = -t'(sinhφ) + x'(coshφ)~##
This implies that ##φ → -φ##, so
##~cosh(-φ) = \frac{1}{(1-u^2)^½}~## and ##~sinh(-φ) = \frac{u}{(1-u^2)^½}~## implies ##~coshφ = \frac{1}{(1-u^2)^½}~## and ##~sinh(φ) = \frac{-u}{(1-u^2)^½}~##.
Therefore,
##t = \frac{t' - ux'}{(1-u^2)^½}##
##x = \frac{x' - ut'}{(1-u^2)^½}##
Is my argument ##φ → -φ## correct? Such that I plugged it in the hyperbolic functions then produced the crucial negative ##~u~## in the numerator of ##sinhφ##?
Yes, your argument is correct. When you plug in ##φ → -φ##, you are essentially taking the inverse transformation, so your result is correct. This is a common technique used when deriving the Lorentz transformation in terms of hyperbolic functions.
Related to Deriving Lorentz transformation by light cone coordinates
What is the purpose of deriving Lorentz transformation by light cone coordinates?
The purpose of deriving Lorentz transformation by light cone coordinates is to understand how objects in motion appear differently to observers in different frames of reference. This is a fundamental concept in understanding Einstein's theory of special relativity.
What are light cone coordinates?
Light cone coordinates are a way of representing space and time in special relativity, where one axis represents time and the other represents the distance from a particular point in space. They are called "light cone" coordinates because they represent the path of light rays in spacetime.
How do light cone coordinates relate to Lorentz transformation?
Light cone coordinates are used to derive Lorentz transformation, which is a set of equations that describe how time and space measurements change between two frames of reference moving at constant velocity relative to each other. By using light cone coordinates, we can visualize how these transformations occur geometrically.
What are the benefits of using light cone coordinates in deriving Lorentz transformation?
Using light cone coordinates in deriving Lorentz transformation allows for a more intuitive understanding of the concept. It also simplifies the mathematics involved, making it easier to visualize and apply in real-world situations.
Are there any limitations to deriving Lorentz transformation by light cone coordinates?
While using light cone coordinates can be helpful in understanding Lorentz transformation, it is not the only way to derive it. Other methods, such as using the Minkowski diagram, can also be used. Additionally, light cone coordinates only work for objects moving at a constant velocity, so they cannot be used for objects undergoing acceleration.
