Deriving minimum escape height and velocity
Why do you need to know the number of moles? How do you convert from kg/mol to kg? You might want to take a look at this page on the mole and molar...The number of moles is needed to find the mass of the molecules, which I need to find the velocity...If I have a certain number of moles, I can multiply that by the mass of the molecule to get the total mass, which I can then plug into the equation to find the velocity.I'll take a look at that link, thanks!The number of moles is needed to find the mass of the molecules, which I need to find the velocity...If I have a certain number of moles
guitarstorm
At which minimum height atoms or molecules are able to leave Earth’s
atmosphere to space? To obtain an approximate estimate use the assumption that molecules can leave if the mean free path, λ, is larger than the scale height H. Write λ and H as a function of height and obtain the minimum “escape” height.
Obtain the minimum escape velocity and compare it to the molecular
velocity of the H-atom and the N2 molecule for conditions of the above
derived escape height.
Use σ=3 10-20 m2, the temperature profile of the US standard atmosphere,
and assume T=1000 K for heights > 100 km. (The real escape height is
about 400 km for the H atom because of the necessary kinetic energy.)
Two equations I started with:
Mean free path: [itex]\lambda=\frac{1}{\sqrt{2}\sigma n_{v}}[/itex]
Scale height: [itex]H=\frac{RT}{g_{0}}[/itex]
I'm assuming I have to set the two equal to each other, so looking through my textbook I found other equations to plug into try to get similar terms in both equations. I've only attempted the escape height part first, since I can't do the rest until I get that...
[itex]n_{v}=\frac{p}{kt}=\frac{pN_{a}}{R^{*}T}[/itex]
So then the mean free path becomes:
[itex]\lambda=\frac{R^{*}T}{\sqrt{2}\sigma pN_{a}}[/itex]
But then we need to find the height (z), so I figured I'd try to plug in [itex]p=\rho gz[/itex].
And then I set [itex]\lambda =H[/itex] as:
[itex]\frac{R^{*}T}{\sqrt{2}\sigma \rho gzN_{a}}=\frac{RT}{g_{0}}[/itex]
I solved for z and got [itex]z=\frac{1}{\sqrt{2}\sigma \rho N_{a}}[/itex], which doesn't really help me...
When I plug in the numbers, I get a very low number as well (around 10^-5), which is obviously not right. I'll try to play around with formulas some more but right now I feel overwhelmed by this problem!:confused:
Are pressure, density, and temperature a function of the height, z? If they are, then the expression that you used to get a z dependence in your equation isn't valid, since [tex]p=\rho g z[/tex] assumes that density is constant. You may want to take a look at the temperature profile of the US standard atmosphere.
Well, I did a lot of work on this question today, including going to my professor's office hours, and I've gotten through most of it but still have a few questions.
I ended up having to use the equation [itex]p=p_{0}e^{-\frac{h}{h_{0}}}[/itex] to relate the pressure and height. Assume [itex]p_{0}=100,000 Pa[/itex], the surface pressure, and [itex]h_{0}=7 km=7000 m[/itex], the scale height at the surface.
When rearranging and plugging in all the values, I get the minimum escape height to be 160 km, which seems reasonable.
The minimum escape velocity, I assume is the Earth's escape velocity of about 11,179 m/s... I went through a little derivation I found on Wikipedia for that.
The final part is where i ran into trouble, where it says to relate the molecular velocity of hydrogen and nitrogen to the escape velocity:
I used the relation [itex]KE=\frac{1}{2}mv^{2}=\frac{3}{2}kT[/itex], but when plugging in the values I got a velocity of magnitude 10^9 m/s for H and N2... This can't be right can it?
Then I used another formula I found online, [itex]v_{rms}^{2}=\frac{3RT}{m}[/itex], and solving for v I got values which seem to make more sense... 4994 m/s for H and 944 m/s for N2.
So basically I'm wondering if the 2nd method I used is correct and why the other one doesn't work.
Thanks!
Thanks!
[itex]KE=\frac{1}{2}mv^{2}=\frac{3}{2}kT[/itex] and [itex]v_{rms}^{2}=\frac{3RT}{m}[/itex] are the same equation. The difference is in the units for m. In the first case, [kT] has units of Joules, so you need a mass in kg. In the second case, since you've used R instead of k ([itex]R=N_A k[\itex] where [itex]N_A[\itex] is Avagadro's constant), [RT] has units of Joules/mole. You need to use the molar mass, which has units of kg/mole. When you get weird answers, double checking that you have the right units can be useful.
I guess I could only use the 2nd equation then, because I have the molar masses...
Is there a way I could have determined the number of moles of each gas at that height in the atmosphere?
Why do you need to know the number of moles? How do you convert from kg/mol to kg? You might want to take a look at this page on the mole and molar mass.
Related to Deriving minimum escape height and velocity
1. How is minimum escape height and velocity calculated?
The minimum escape height and velocity can be calculated using the formula: h = ve²/2g, where h is the minimum escape height, ve is the minimum escape velocity, and g is the gravitational acceleration on the planet.
2. What is the significance of determining the minimum escape height and velocity?
Determining the minimum escape height and velocity is important for space travel and understanding the physics of escaping a planet's gravitational pull. It can also help in designing spacecrafts and rockets for successful launches.
3. How does the mass of a planet affect the minimum escape height and velocity?
The mass of a planet directly affects the minimum escape height and velocity. The more massive a planet is, the higher its escape height and velocity will be. This is because the gravitational pull of a more massive planet is stronger, requiring more energy to escape its pull.
4. Can the minimum escape height and velocity be determined for any planet?
Yes, the minimum escape height and velocity can be determined for any planet as long as its mass and gravitational acceleration are known. However, it may vary depending on the planet's atmospheric conditions and other factors such as rotation and magnetic field.
5. How does the shape of a planet affect the calculation of minimum escape height and velocity?
The shape of a planet does not significantly affect the calculation of minimum escape height and velocity. This is because the formula used for calculation assumes a spherical planet. However, if a planet's shape is irregular, it may slightly affect the escape trajectory and the required velocity for escape.
