Deriving Reduction of Order Formula: Krazy G's Yahoo Answers Q
In summary, the reduction of order formula is derived from the second order linear differential equation and can be used to solve such equations by reducing them to a first order linear differential equation. However, it can only be used for equations with continuous coefficients and has limitations such as not being applicable for higher order or non-homogeneous equations. There are other methods available for solving second order linear differential equations, but the reduction of order formula remains a useful tool for certain types of equations.
MarkFL
MHB
13,288
Here is the question:
If In = ∫ pi/2 AND 0 x^n sin(x) dx ; show that; In = n(pi/2)^n−1 - n(n-1)In−2 (n =/>2):?
[USE INTEGRATION TABLES!]
It is hard to write this equation out, here are a few notes;
In is not LN it is a capital i with n sitting slightly lower.
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Krazy G,
We are given:
\(\displaystyle I_n=\int_{0}^{\frac{\pi}{2}} x^n\sin(x)\,dx\) where \(\displaystyle 2\le n\)
and we are asked to derive the given reduction of order formula:
\(\displaystyle I_n=n\left(\frac{\pi}{2} \right)^{n-1}-n(n-1)I_{n-2}\)
To begin, let's use integration by parts where:
\(\displaystyle u=x^n\,\therefore\,du=nx^{n-1}\,dx\)
\(\displaystyle dv=\sin(x)\,dx\,\therefore\,v=-\cos(x)\)
Hence, we may state:
\(\displaystyle I_n=\left.-x^n\cos(x) \right|_{0}^{\frac{\pi}{2}}+n\int_{0}^{\frac{\pi}{2}} x^{n-1}\cos(x)\,dx\)
\(\displaystyle I_n=-\left(\frac{\pi}{2} \right)^n\cos\left(\frac{\pi}{2} \right)+0^n\cos(0)+n\int_{0}^{\frac{\pi}{2}} x^{n-1}\cos(x)\,dx\)
\(\displaystyle I_n=n\int_{0}^{\frac{\pi}{2}} x^{n-1}\cos(x)\,dx\)
Let's use integration by parts again where:
\(\displaystyle u=nx^{n-1}\,\therefore\,du=n(n-1)x^{n-2}\)
\(\displaystyle dv=\cos(x)\,dx\,\therefore\,v=\sin(x)\)
\(\displaystyle I_n=\left.nx^{n-1}\sin(x) \right|_{0}^{\frac{\pi}{2}}-n(n-1)\int_{0}^{\frac{\pi}{2}}x^{n-2}\sin(x)\,dx\)
Observing that \(\displaystyle \int_{0}^{\frac{\pi}{2}}x^{n-2}\sin(x)\,dx=I_{n-2}\) we may write:
\(\displaystyle I_n=n\left(\frac{\pi}{2} \right)^{n-1}\sin\left(\frac{\pi}{2} \right)-n\cdot0^{n-1}\sin(0)-n(n-1)I_{n-2}\)
Shown as desired.
FAQ: Deriving Reduction of Order Formula: Krazy G's Yahoo Answers Q
What is the derivation of the reduction of order formula?
The reduction of order formula is derived from the second order linear differential equation, y'' + p(x)y' + q(x)y = 0, where p(x) and q(x) are continuous functions. By using the substitution y = uv, we can reduce the order of the equation to a first order linear differential equation, which can then be solved using standard techniques.
How do you use the reduction of order formula to solve a differential equation?
To use the reduction of order formula, you first need to have a second order linear differential equation in the form y'' + p(x)y' + q(x)y = 0. Then, you can substitute y = uv and solve for v using the resulting first order equation. Finally, you can use the formula y = u∫vdx + C to find the general solution to the original second order equation.
Can the reduction of order formula be used for all types of differential equations?
No, the reduction of order formula can only be used for second order linear differential equations with continuous coefficients. It cannot be used for higher order equations or equations with discontinuous coefficients.
What are the limitations of the reduction of order formula?
The reduction of order formula can only be used for second order linear differential equations with continuous coefficients. It also cannot be used for equations with variable coefficients or non-homogeneous equations. Additionally, the formula may not always yield a solution for the original equation.
Are there any other methods for solving second order linear differential equations?
Yes, there are other methods such as the method of undetermined coefficients and the method of variation of parameters. These methods can be used for a wider range of equations, including non-homogeneous and variable coefficient equations. However, the reduction of order formula is still a useful tool for solving certain types of equations.
