Deriving the 4-momentum of a free particle moving in curved spacetime
In summary, the conversation discusses the Lagrangian and canonical 4-momentum for a free particle with rest mass ##m## moving along a geodesic in a curved spacetime with metric ##g_{\mu\nu}##. The 4-momentum, expressed in contravariant form, is given by ##P^\alpha=m\ \frac{dx^\alpha}{d\tau}##, but caution should be taken when interpreting the components of ##P^\alpha## as energy and momentum as it requires the frame of an observer.
jcap
170
Consider a free particle with rest mass ##m## moving along a geodesic in some curved spacetime with metric ##g_{\mu\nu}##:
$$S=-m\int d\tau=-m\int\Big(\frac{d\tau}{d\lambda}\Big)d\lambda=\int L\ d\lambda$$
$$L=-m\frac{d\tau}{d\lambda}=-m\Big(-g_{\mu\nu}\frac{dx^\mu}{d\lambda}\frac{dx^\nu}{d\lambda}\Big)^{1/2}$$
The canonical 4-momentum ##P_\alpha## can be derived from the Lagrangian ##L## using the following calculation:
\begin{eqnarray*}
P_\alpha &=& \frac{\partial L}{\partial(dx^\alpha/d\lambda)} \\
&=& \frac{m}{2}\frac{d\lambda}{d\tau}\Big(g_{\alpha\nu}\frac{dx^\nu}{d\lambda}+g_{\mu\alpha}\frac{dx^\mu}{d\lambda}\Big) \\
&=& m\ g_{\alpha\nu}\frac{dx^\nu}{d\tau} \\
&=& m\ \frac{dx_\alpha}{d\tau}
\end{eqnarray*}
where we have used the fact that the metric ##g_{\mu\nu}## is symmetric.
Thus, expressed in contravariant form, we have derived an expression for the 4-momentum ##P^\alpha## given by
$$P^\alpha=m\ \frac{dx^\alpha}{d\tau}$$
using a completely general metric ##g_{\mu\nu}##.
Is it correct to interpret the components of ##P^\alpha## in the following manner:
##P^0## is the energy of the particle,
##P^i## is the 3-momentum of the particle in the ##\partial_i## direction?
\begin{eqnarray*}
\end{eqnarray*}
Warning! The quantity ##x_\alpha## does not make any sense in GR. ##x^\alpha## are just coordinates, they are not the components of a vector and you cannot raise and lower the index. You also cannot move the ##g_{\alpha\nu}## inside the derivative at will. It depends on the coordinates and therefore on ##\tau## along the world line.
No. The split into momentum and energy requires the frame of some observer. You are not guaranteed that your coordinates define such a frame.
Thanks for the reply
FAQ: Deriving the 4-momentum of a free particle moving in curved spacetime
What is the 4-momentum of a free particle?
The 4-momentum of a free particle is a vector quantity that describes the energy and momentum of the particle in four-dimensional spacetime. It includes the particle's rest mass, energy, and momentum in the three spatial dimensions.
How is the 4-momentum of a free particle derived?
The 4-momentum of a free particle can be derived using the principles of special relativity and the equations of motion in curved spacetime. This involves calculating the energy and momentum of the particle in three spatial dimensions and then transforming them into four-dimensional spacetime using the metric tensor.
What is the role of curved spacetime in deriving the 4-momentum of a free particle?
Curved spacetime is essential in deriving the 4-momentum of a free particle because it accounts for the effects of gravity on the particle's motion. In curved spacetime, the particle's path is not a straight line, so its energy and momentum must be calculated in four dimensions rather than just three.
Can the 4-momentum of a free particle be used to describe particles in all types of motion?
Yes, the 4-momentum of a free particle can be used to describe particles in all types of motion, including straight-line motion, circular motion, and accelerated motion. This is because it takes into account the particle's energy and momentum in all four dimensions, allowing for a comprehensive description of its motion.
Are there any limitations to using the 4-momentum of a free particle in curved spacetime?
One limitation of using the 4-momentum of a free particle in curved spacetime is that it is only applicable to particles that are not affected by external forces. In other words, the particle must be truly "free" in order for the 4-momentum to accurately describe its motion. Additionally, the equations used to derive the 4-momentum may become more complex in highly curved spacetimes, making calculations more challenging.
