Engineering Deriving the Cable Equation (neuroscience) from Fundamental Physics Laws
The discussion focuses on deriving the Cable Equation in neuroscience using fundamental physics laws, particularly through the lens of anisotropic conductivity modeled as a cylinder. The author employs the current density equation, incorporating a Heaviside function to indicate zero conductivity outside the cylinder, and establishes the potential function accordingly. The first Maxwell equation is utilized alongside charge conservation principles, leading to an integral form that the author struggles to simplify into the desired equation. Suggestions are made to incorporate the electric potential into the equations and to substitute electric field expressions for further integration. The conversation emphasizes the need to connect Ohmic principles with Maxwell's equations to advance the derivation.
Icaro Lorran
I want to derive the cable equation 12 on this link: https://en.wikipedia.org/wiki/Cable_theory
The way wikipedia derives wasn't very convincing to me, so I wanted to start from Maxwell's equations and some basic principles instead.
##\nabla \cdot D = \rho##
##\frac{\partial \rho}{\partial t} + \nabla \cdot J = 0##
##J = \sigma E##
> Note: I am using SageMath to do the manipulations, I will attach it with the post
I modeled the problem as a cylinder of height ##\Delta z## and anisotropic conductivity: the conductivity along the axis is different from the one along the radius. Using ##J = \sigma E##, where ##\sigma## is a tensor encoding both directions, I can write the total current as
$$J = \sigma_z (1 - H(r-a)) E_z \hat{z} + \sigma_r (1 - H(r-a)) E_r \hat{r} $$
The reason I added the heaviside function is that the conductivity should be zero outside the tube. With a similar reasoning, I also said that the potential must vanish outside as well
$$V(t, r, z) = u(t,z)(1 - H(r-a))$$
I don't include $\theta$ due to rotational symmetry.
The first Maxwell equation for a linear medium is
$$\nabla \cdot D = \rho$$
With $D = \epsilon E$, where $\epsilon$ is also a tensor:
$$\epsilon = \epsilon_0 \hat{z} \otimes \tilde{z} + \epsilon(1 - H(r-a)) \hat{r} \otimes \tilde{r} + \epsilon_0 H(r-a) \hat{r} \otimes \tilde{r}$$
Plugging that on $D$, it becomes
$$D = (\epsilon + (\epsilon_0 - \epsilon) H(r-a))E_r \hat{r} + \epsilon_0 E_z \hat{z}$$
Now, my initial plan was to join the first Maxwell equation with the equation for conservation of charge (consider all these integrals to be closed):
$$Q = \iint D \cdot \mathrm{d}^2 \vec{r} $$
and
$$\iint J \cdot \mathrm{d}^2 \vec{r} = -\frac{\mathrm{d}}{\mathrm{d} t} Q$$
$$\iint J \cdot \mathrm{d}^2 \vec{r} = -\frac{\mathrm{d}}{\mathrm{d} t} \iint D \cdot \mathrm{d}^2 \vec{r}$$
$$\iint \left( J + \frac{\partial}{\partial t} D\right) \cdot \mathrm{d}^2 \vec{r} = 0$$
The part that I get stuck is how to go on from here. I tried to use a cylinder as a surface to enclose everything, but what comes out of it doesn't really resemble the desired equation. I did notice that integrating the result over ##r##, does get something close, but I don't have any explanation as to why that works.
Here's the link to the notebook (I couldn't attach): https://github.com/icarosadero/cable_equation/blob/main/cable_equation.ipynb
Cable theory involves Ohmic principles more than Maxwell. You have to incorporate the electric potential ##V## into your equations. I would try to integrate it after putting in ##E## for where there is an electric field (ex. ##J=\sigma E##) in your integrals and then substitute ##E=V/d##.
  • · Replies 26 ·
  • · Replies 29 ·
  • · Replies 29 ·
