Deriving the ionization energy of a hydrogen atom
The discussion focuses on deriving the ionization energy of a hydrogen atom, which is known to be -13.60 eV. The initial calculations involved potential energy based on electrostatic force, yielding a value of approximately -27.22 eV, indicating a misunderstanding of the total energy. The key correction was recognizing the need to include the kinetic energy of the electron, which, when added to the potential energy, correctly results in the desired ionization energy. Additionally, the conversation touches on the implications of quantum mechanics, such as the transition from the ground state to ionization and the relevance of the fine structure constant. The final understanding aligns with the principles of Bohr's model and the relationship between potential and kinetic energy in atomic systems.
Tommy R
Hi, I've just gotten started with basic quantum physics in physics class and we've just talked about ionization energy. It is stated that the energy of a hydrogen atom is -13.60eV (or -2.179aJ). I assume this is the potential energy (and that this is the reason the atom has a lower mass than the sum of the mass of its components on their own). I'm curious as to how this can be derived.
My book briefly states that the radius of the hydrogen atom (i.e. the distance between electron an proton) is 5.29*10-11 m. My thinking is the following: The electrostatic force on the electron is F=k Q1 Q2 / r2 = - k e2 / r2 in this case. The potential energy is thus Ep = F r = -k e2 / r = -8.988*109 (1.60218*10-19)2 / (5.29*10-11) ≈ -4.36*10-18 J ≈ -27.22eV ≈ 2*(-13.60eV).
So I'm off by a factor of two. But I feel like I'm on the right track since my calculated energy is so close to the double of what I want to get. I'm thinking that the electrons wave function shouldn't have any effects on this, but I'm not very familiar with this. What am I missing? Thanks for any input!
You forget to add the kinetic energy of the electron :)
Likes Tommy R
I tried this out and got it working! And it made a lot of sense, Thanks!
Assuming the electron is obeying bohr's model of the atom its centripetal acceleration a = F / m, and by a = v2 / s, v = √(a s). The kinetic energy Ek = ½ m v2 = ½ e2/s 8.988*109 ≈ 2.18*10-18 J. This makes the extra energy gained of the assembly of the atom E = Ep + Ek ≈ -2.18*10-18 J ≈ -13.60eV which is what I was after!
Except that ionization energy is essentially a transition from n=1 to n=∞ corresponding to emission/absorption of a photon.
less ground state lamb shift h x 8.183807 GHz = 2.17870936 E-18 Joules. Don't quite know how that ties in (if at all) with E = Ep + Ek ? In the formula me is the reduced electron mass and α is the fine structure constant.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • Sticky
10K
  • · Replies 26 ·
