Deriving the progressive mechanical wave equation
In summary, the two equations describe two different physical situations in which the wavefunction will take two different initial values.
Nikhil Rajagopalan
72
Is it correct to state that a progressive wave, originates when a simple harmonic motion is imparted continuously to adjacent particles from one direction to another moving with a velocity v. Using this idea, substituting (t - x/v) instead of t is the simple harmonic motion function y=Asin(ωt), we obtain the final answer as y= Asin(ωt - kx).
In another method, drawing a sine wave and finding out the function for a sine wave propagating towards right with a velocity v , substituting (x - vt) instead of x, the propagating wave function is obtained as y= Asin(kx- ωt).
Why is there a phase difference here?
Notice: the first one gets you ##y(x,t)=-A\sin (kx-\omega t)##
If you want the same phase, then the first sub should be ##x/v - t \to t##, or use a cosine wave.
The difference is because of how the wave propagates.
Think of the physical situation being described in each case: In the first you grab a point, say at x=0, and wave it first up and then down (and suppress the -x propagating solution); in the second you have a wave already and you shove it to one side - so that x=0 goes down first and then up.
The maths is just describing that correctly.
Thank you Simon Bridge, the answer was really helpful.
For the wave traveling towards left, the equations is Asin(kx + ωt). How does the same mathematical equation explain the possibility of two initial conditions. In the case of the wave traveling towards right, Asin(kx - ωt) and Asin(ωt - kx) gives two initial conditions Asin(kx) and -Asin(kx) on substituting t=0. Explaining the possibility of two different initial movements. In the case of waves traveling towards left, this difference doesn't come up. How can we explain this situation physically.
Related to Deriving the progressive mechanical wave equation
1. What is the progressive mechanical wave equation?
The progressive mechanical wave equation is a mathematical representation of the behavior of mechanical waves, such as sound or water waves. It describes the relationship between the wave's properties, such as its speed and wavelength, and the medium through which it travels.
2. How is the progressive mechanical wave equation derived?
The progressive mechanical wave equation is derived using the principles of wave mechanics, specifically the wave equation and the equations of motion. It involves considering the forces acting on a small element of the wave and applying Newton's laws of motion to find the resulting equation.
3. What are the key assumptions in deriving the progressive mechanical wave equation?
The key assumptions in deriving the progressive mechanical wave equation include a linear medium, small displacements of the wave particles, and the absence of damping or energy dissipation. These assumptions allow for a simplified model of a wave that is easy to work with mathematically.
4. How is the progressive mechanical wave equation related to the speed of the wave?
The progressive mechanical wave equation includes a term that represents the speed of the wave. This term is dependent on the properties of the medium, such as its density and elasticity. Therefore, the progressive mechanical wave equation directly relates the speed of the wave to the properties of the medium through which it travels.
5. What are some real-life applications of the progressive mechanical wave equation?
The progressive mechanical wave equation is used in various fields, including acoustics, seismology, and oceanography. It is used to model and understand the behavior of sound waves, earthquake waves, and ocean waves, respectively. It is also used in engineering to design structures that can withstand the effects of mechanical waves.
  • Other Physics Topics
