I Deriving the relativistic rocket equation with exhaust efficiency
The discussion revolves around the relativistic rocket equation and its derivation, particularly when factoring in the annihilation of propellant to usable exhaust. The user is attempting to derive the equation from Wikipedia but is struggling to connect it with the standard form of the relativistic rocket equation. They successfully reduce the equation to its simpler form when the annihilation factor is zero but cannot reconcile their derivation with the more complex version that includes the fraction of usable exhaust. Questions arise regarding the definitions of exhaust velocity and the variables used in the equation, indicating a need for clarification on these terms to resolve the derivation issues. The conversation highlights the complexities of relativistic physics and the challenges in understanding advanced concepts.
halcyon_zomboid
TL;DR Summary
My derivation produces a relativistic rocket equation with exhaust "efficiency" that disagrees with this one: https://en.wikipedia.org/wiki/Antimatter_rocket#Modified_relativistic_rocket_equation
Hi,
I'm looking at this relativistic rocket equation on Wikipedia. Something doesn't make sense here, and I can't find a derivation for this equation in the linked source, so I'm trying to derive it myself with limited success.
$$\frac{\mathrm{d}M}{M}=-\frac{\mathrm{d}v(1-v_\mathrm{ex}\frac{v}{c^2})}{(1-\frac{v^2}{c^2})(-v_\mathrm{ex}\frac{v^2}{c^2}+(1-a)v+av_\mathrm{ex})}
This is purportedly the relativistic rocket equation when accounting for annihilation to usable exhaust. To quote Wikipedia, " ##a## is the fraction of the original (on board) propellant mass (non-relativistic) remaining after annihilation (i.e., ##a=0.22## for the charged pions)."
I can see that this reduces to the usual relativistic rocket equation when ##a=0##:
\frac{\mathrm{d}M}{M}=-\frac{\mathrm{d}v}{v_\mathrm{ex}(1-\frac{v^2}{c^2})}
However, I can't seem to derive the above equation. Here's my attempt (which succeeds for the normal relativistic rocket equation):
In the COM frame, the rocket's initial mass is ##M+\mathrm{d}M##. Its final mass is ##M## and its velocity in this frame is ##\mathrm{d}v'##. Let's say the exhaust has mass ##\mathrm{d}m## and velocity ##v_\mathrm{ex}##, so if all the exhaust were usable, energy conservation would give
$$(M+\mathrm{d}M)c^2-Mc^2=\frac{c^2\,\mathrm{d}m}{\sqrt{1-\frac{v_\mathrm{ex}^2}{c^2}}}
(to first order in ##\mathrm{d}v'##). However, in reality, not all of the exhaust is usable. Let's say only a fraction ##\alpha## of the energy loss ##c^2\,\mathrm{d}M## is captured by beamed core exhaust pions:
\alpha c^2\,\mathrm{d}M=\frac{c^2\,\mathrm{d}m}{\sqrt{1-\frac{v_\mathrm{ex}^2}{c^2}}}.
Okay, now let's look at momentum. For simplicity's sake, we'll assume all the useless energy is radiated symmetrically, so there's no effect on momentum. The final momentum of the rocket is ##M\,\mathrm{d}v'## (to first order in ##\mathrm{d}v'##), and that of the exhaust is
-\frac{v_\mathrm{ex}\,\mathrm{d}m}{\sqrt{1-\frac{v_\mathrm{ex}^2}{c^2}}}
=-\alpha v_\mathrm{ex}\,\mathrm{d}M
But doesn't this then mean that
\frac{\mathrm{d}M}{M}=-\frac{\mathrm{d}v'}{\alpha v_\mathrm{ex}}=-\frac{\mathrm{d}v}{\alpha v_\mathrm{ex}(1-\frac{v^2}{c^2})}
when we go back to the lab frame? I get nothing resembling the equation at the start.
Is there something wrong with my derivation?
What are ##v_{ex}## and ##v## in your formula ? I don' t find the former in Wikipedia you referred.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
