Deriving to find speed (angular motion)
In summary: The relationship between the two is that, for constant radius, the average speed multiplied by the time interval is equal to the instantaneous speed multiplied by the time interval. In summary, the lecturer is discussing the relationship between translational speeds and angular velocities for circular motion. The derivative of theta with respect to time, d(theta)/dt, is defined as the instantaneous angular velocity, while delta theta over delta time represents the average angular velocity. The equation v = rω relates the linear speed to the angular velocity, where r is the radius. In this case, the value of the angular velocity can be calculated using either the average or instantaneous method.
Erenjaeger
141
Going through a lecture recording from a lecture I missed the lecturer says "to get the relationship between translational speeds and angular velocities we will take a differential" what is that relationship she is talking about? does she mean converting between the two? The derivative was,
v=ds/dt = d(rθ)/dt
v = r d(θ)/dt ← the r was pulled out the front here because this was assuming an unchanging radius.
therefore v = rω
i understand that rω comes about because the d(θ)/dt was defined as the angular velocity, whereas i thought it was just Δθ/Δt that was angular velocity? not the derivative of θ with respect to t, which is was d(θ)/dt is right?
Aslo would someone be able to show me how I would apply this to a question?
v=ds/dt = d(rθ)/dt
v = r d(θ)/dt
v = rω
Would applying that last part, v=rω does that just mean to find the velocity (as a scalar) it is just the product of the radius and angular velocity ??
What you are asking is the relationship between speed and angular velocity for circular motion.
Angular velocity, like linear velocity, can be analysed using small finite changes in time or by continuos changes in time. In the first case, you have a small, finite time interval ##\Delta t## and a small, finite change of angle ##\Delta \theta##. The (average) angular velocity during this interval is:
##\omega = \Delta \theta / \Delta t##.
You could think of this as the measurement taken during an experiment.
Theoretically, however, you can also imagine the angle to be changing continuously with time, in which case ##\theta## is a function of time and you can get an instantaneous angular velocity by differentiating this function:
##\omega = \frac{d\theta}{dt}##
In both cases if ##r## is constant, then the linear speed is given by:
##v = r\omega##
##v = r\omega##
oh right so the derivative is just for instantaneous angular velocity and then delta theta over delta time is the average, makes sense.
for v=rω does it matter how you work out the value ω or do you specifically have to either use average angular or instantaneous velocity ??
thanks.
thanks.
In one case you get the average speed over the finite time interval. In the other case, you get an instantaneous speed as a function of time.
Related to Deriving to find speed (angular motion)
1. What is the definition of angular speed?
Angular speed, also known as rotational speed, is a measure of how fast an object is rotating or moving in a circular path. It is typically measured in radians per second (rad/s) or revolutions per minute (rpm).
2. How is angular speed calculated?
Angular speed is calculated by dividing the distance traveled in a circular path by the time it takes to travel that distance. This can be represented by the formula: angular speed = Δθ/Δt, where Δθ is the change in angle and Δt is the change in time.
3. What is the difference between angular speed and linear speed?
Angular speed is a measure of how fast an object is rotating around an axis, while linear speed is a measure of how fast an object is moving in a straight line. Angular speed is measured in radians per second, while linear speed is measured in meters per second.
4. How does centripetal acceleration relate to angular speed?
Centripetal acceleration is the acceleration towards the center of a circular path that keeps an object moving in a circular motion. It is directly proportional to the square of the angular speed, meaning that as the angular speed increases, so does the centripetal acceleration.
5. What are some real-life applications of angular speed?
Angular speed is used in many different fields, such as engineering, physics, and astronomy. Some common real-life applications include calculating the speed of a spinning fan, determining the rotation rate of the Earth, and analyzing the speed of a car’s tires as it turns a corner.
