Deriving Voltage from the Inductor Equation
In summary, the given problem involves finding the voltage and time when power is zero in a circuit with an inductor and a given current equation. The solution involves integrating the voltage equation, but there seems to be a discrepancy with the given solution and the implied values for A1 and A2. It is recommended to bring this issue to the attention of the person who assigned the problem.
Nicole D
L = 20mH = 20 x 10-3 H
i = 40 mA for t≤0
i = A1e-10,000t + A2e-40,000t A for t≥0
The voltage at t=0 is 28 V.
I have to find the equation for the voltage for t>0.
Then I have to find the time when power is zero.
v(t) = L* di/dt
p(t) = L*i* di/dt
I know that current through an inductor has to be continuous, so at t=0, I can say:
A1 + A2 = 40 x 10-3 A
I then found di/dt:
di/dt = -10,000A1e-10,000t - 40,000A2e-40,000t
Since v = L di/dt:
v = (20 x 10-3 H)*(-10,000A1e-10,000t - 40,000A2e-40,000t)
v = -200A1e-10,000t - 800A2e-40,000t
At t=0, v=28 V, so:
v(t=0) = -200A1 - 800A2 = 28 V
So I have the following two equations:
When I solve these using matrices on my calculator, I get:
A1 = 0.1
A2 = -0.06
When I plug those into the equation for v, I get:
v(t) = -20A1e-10,000t + 48A2e-40,000t
This answer is one of the multiple choice answers. However, the system tells me this answer is wrong and the correct answer is:
v(t) = 18A1e-10,000t + 10A2e-40,000t
I don't understand why my answer is wrong, so any explanation would be appreciated!
Once I understand that, I know that to find the time when power is zero, I just set p(t) = L*i* di/dt to zero and solve for t.
Likes Merlin3189
I don't understand your solution or the solution that is reportedly correct. If you plug in numerical values for A1 and A2, the expression for v(t) should not have A1 and A2 in it. Actually ##v=-L\frac{di}{dt}## but that will only change the overall sign of v(t) without changing the values of the coefficients in front of the exponentials.
Yes, that's clearly a typo.
I like your answer better than theirs. But, I would suggest that you read the problem carefully and make sure you wrote it correctly at the start.
Likes Merlin3189
Yes, my last two equations for v(t) should not have A1 and A2 in them. Sorry for the typo.
I double checked that I copied everything over correctly and I can't find an obvious error.
The solution ##V(t)=18e^{-10000t}+10e^{-40000t}## is incompatible with the the initial current value of 40 mA. Assume that this solution is correct, then you can integrate to find ##I(t)## from$$I(t)=-\frac{1}{L}\int V(t)dt$$and finally calculate the initial current ##I(0)##. I did that and found about 100 mA, but you should check it out for yourself. So it looks like that either the supposed answer is incorrect or the initial value of 40 mA is incorrect.
Likes scottdave
I found the same, but then I remembered there is a constant added from the integration. The voltage tells you how the current changes, not what it's value is.
However, the values implied by the voltage equation for A1 & A2 do not give the correct initial current in the given current equation.
There's probably more to this than meets the eye because of the two different time constants. @Nicole D can you post the circuit diagram that goes with this and the original statement of the problem? Thanks.
This is a picture of the original problem statement. There wasn't a circuit diagram with it. It is possible that the given solution is wrong - I know other people are having trouble with this problem.
Thank you for posting this. It looks like there are no hidden pitfalls. Frankly, I don't see how the supposedly correct solution is actually correct. However, I think your original solution is also incorrect. You should use ##V(t)=-L\frac{di}{dt}## to get the answer. I was wrong in post #2 when I claimed that the negative sign will just change the overall sign of ##V(t)##. I also think you should bring to the attention of whoever assigned you this problem that there appears to be something wrong with it.
"passive sign convention" is important here. It means that a positive inductor voltage increases the inductor current. ##V(t)=L\frac{di}{dt}##
v(t) = -20e-10,000t + 48e-40,000t
That is the correct answer. What explanation did your teacher give for this result not being marked correctly, @Nicole D
Related to Deriving Voltage from the Inductor Equation
1. What is the inductor equation and how is it used to calculate voltage?
The inductor equation is V=L(di/dt), where V is voltage, L is inductance, and di/dt is the rate of change of current. This equation is used to calculate the voltage across an inductor at any given time by multiplying the inductance value by the rate of change of current.
2. Can the inductor equation be used for both DC and AC circuits?
Yes, the inductor equation can be used for both DC and AC circuits. In DC circuits, the rate of change of current is constant, while in AC circuits, it varies with time. However, the inductance value remains the same in both cases.
3. How does the inductor equation relate to Faraday's law of induction?
The inductor equation is a direct result of Faraday's law of induction, which states that a changing magnetic field will induce an EMF (voltage) in a conductor. In the case of an inductor, the changing current creates a changing magnetic field, which then induces a voltage across the inductor.
4. Are there any practical applications of the inductor equation?
Yes, the inductor equation has many practical applications. One example is in power supplies, where inductors are used to smooth out the output voltage by storing and releasing energy. Inductors are also used in electronic filters, sensors, and motors.
5. Can the inductor equation be simplified for easier calculation?
Yes, the inductor equation can be simplified by using the concept of reactance, which is the opposition to the flow of current in an AC circuit. For an inductor, the reactance is equal to 2πfL, where f is the frequency of the AC signal. This simplification is useful for circuit analysis and design.
