Describe graph reachability with two total orders?
  • Thread starter mXSCNT
  • Tags
    Graph
In summary, the conversation discusses the concept of a directed acyclic graph (DAG) and the definition of a "flippable" DAG. A flippable DAG has two total orders, O1 and O2, in which the order of two nodes V and W is switched if they are apart. The advantage of a flippable DAG is that it allows for constant time determination of whether there is a path between two nodes. However, not all DAGs are flippable and the minimum number of total orders needed to make a DAG flippable is still unknown. The conversation also raises questions about characterizing flippable DAGs and finding the minimum number of total orders needed.
mXSCNT
315
Suppose you have a directed acyclic graph (a DAG) G. A total order for G is a list of the nodes in G, such that if there is a path from node A to node B, then A appears before B in the total order.
Define (I don't know if there's already a standard term for this) two nodes V and W to be "apart" if there is no directed path from V to W, and no directed path from W to V.
Define G as "flippable" if there exist two total orders of G, O1 and O2, such that if a node V is apart from a node W, then the order of V and W is switched between O1 and O2 (either V appears before W in O1 and after W in O2, or W appears before V in O1 and after V in O2).
The advantage of this is that if G is flippable, you can tell in constant time whether there is a path from node V to node W, by looking to see whether their order in O1 and O2 is switched.
Most DAGs you draw by by hand seem to be flippable, even somewhat complicated ones. Here's an example of a simple, flippable DAG. (represented by the paths the DAG contains):
a -> c -> f
b -> d -> f
b -> c -> e
O1 = abcedf
O2 = bdacfe
You can verify that O1 and O2 work by listing which nodes are apart from which nodes, and checking their order is switched:
a: b and d
b: a
c: d
d: a, c, and e
e: d and f
f: e
To construct O2 (if you have a valid O1), you just start at the end of O1, and work backwards inserting nodes into O2. Insert each node as far forward into O2 as you can, without inserting it after any of its children. Using the previous example:
O1 = abcedf
Building O2, showing the steps:
f
df
dfe
dcfe
bdcfe
O2 = bdacfe
After quite some time I realized what rule to follow when you are trying to construct O1. If A is apart from B and C, and there is an edge B -> C, and B has already been added to O1, then you can't add A to O1 until C has been added first. It's not hard to realize why this is true, especially after trying a few examples.
It didn't take me that long after realizing that rule to find an example of a non-flippable DAG (I spent some time hoping to find an algorithm to always find O1 and O2 for a DAG - my quest was in vain!) Here is the non-flippable DAG:
A -> D
B -> D
B -> E
C -> E
C -> F
A -> F
The graph is symmetric so I'll start by putting any root node into O1. Let's choose B.
O1=B
From here we have to choose A or C. But if we choose A, we run afoul of our rule, because B and E are apart from A, and B is in O1 but E is not, and B -> E is an edge. If we choose C, the problem is that B and D are apart from C, and B is in O1 but D is not, and B -> D is an edge. Thus, the graph is not flippable.
Certain graphs are flipabble, but tricky, involving dead ends. For example:
A -> C
B -> D -> C
B -> E
Suppose we start with B. Our rule doesn't immediately rule out choosing D or E next, so we might choose D. But now, we can't choose A because of B -> E, and we can't choose E because of D -> C! The problem can be solved by chosing E instead, to get O1=BEDAC. (And O2=ABDCE).
So - what now?
Well, how can we characterize which graphs are flippable? Is there a simple algorithm?
Suppose we define a DAG to be "3-flippable" (or generally "N-flippable") if there are N total orders O1, O2, ..., ON such that if a node A is apart from B, then A appears before B in at least one total order, and A appears after B in at least one other total order. This is almost as good for the original purpose, because that still let's us decide whether there is a path from A to B in a small number of computational steps.
There's definitely some N for which any DAG is N-flippable, since for any two nodes A and B that are apart it is easy to construct a total order where A appears before or after B, if we don't care about the order of the nodes. But we still have the question, what is the minimum N for which a particular DAG is N-flippable? And how can we generate O1, O2, ..., ON?
Also, is the minimum N for which a particular DAG is N-flippable bounded by a constant, or are there DAGs that aren't M-flippable but are M+1-flippable for any M? What's N for the "zigzag" graph
1 -> 2
3 -> 2
3 -> 4
5 -> 4
5 -> 6
7 -> 6
7 -> 8
2n+1 -> 2n
2n+1 -> 2n+2
1 -> 2n+2
Mathematics news on Phys.org
Hi,
that sounds really cool.
Interestingly I had very similar ideas while thinking about dags and also hoped at the beginning, two orderings would suffice for each and any graph, just to find out that it does not.
Did you further follow the idea with N orderings?
Related to Describe graph reachability with two total orders?
1. What is graph reachability?
Graph reachability is the ability to determine if there is a path between two vertices in a graph. In other words, it is the process of determining whether it is possible to travel from one vertex to another by following the edges of the graph.
2. What are total orders in graph reachability?
Total orders in graph reachability refer to the concept of a linear ordering of the vertices in a graph. This means that each vertex is assigned a unique position or rank in the ordering, and the ordering must satisfy certain conditions to be considered a total order.
3. How does reachability work with two total orders?
In graph reachability with two total orders, two different linear orderings of the vertices are used to determine reachability between two vertices. This allows for a more efficient and accurate determination of reachability, as compared to using only one total order.
4. What are the benefits of using two total orders in graph reachability?
Using two total orders in graph reachability can provide a more accurate and efficient way to determine reachability between vertices. It can also help to reduce the time and space complexity of the algorithm used for reachability, making it more practical for larger and more complex graphs.
5. What are some real-world applications of graph reachability with two total orders?
Graph reachability with two total orders has many real-world applications, such as in transportation networks, social networks, and computer networks. It can be used to determine the shortest path between two locations, find connections between people, and optimize data routing in networks, among other uses.
  • Mechanical Engineering
  • General Math
  • General Math
  • General Math
