Describe how you could use a pith ball as an electroscope
A pith ball can function as an electroscope by being charged either positively or negatively to observe attractive or repulsive forces. To use it effectively, one must describe the apparatus and explain how to charge the pith ball. The charged pith ball can attract neutral objects, which helps identify their charge. However, caution is needed to avoid misleading results, such as a positively charged object attracting a similarly charged pith ball. Overall, the pith ball can serve as a simple tool for demonstrating electrostatic principles.
sarah123
Describe how you could use a pith ball as an electroscope to identify the nature and presence of charge
Electrostatics Theory
Would it still work in a similar manner as an actual electroscope where you would charge it either positively or negatively and then observe attractive or repulsive forces or is there an easier and more efficient method?
sarah123 said:
Homework Statement: Describe how you could use a pith ball as an electroscope to identify the nature and presence of charge
Relevant Equations: Electrostatics Theory
Hi @sarah123 and welcome to PF. No one has replied yet so here are a few thoughts.
You haven't actually given your answer to the h/w question, so it's hard to reply to your query. But yes, the underlying approach is to charge the pith ball (PB) positively or negatively.
You need to
- describe the apparatus (even though it's simple);
- state how you would you give the PB a positive charge and how would you give it a negative charge;
- give a brief explanation of how you would then use the apparatus.
For a good answer, you might want to consider the following issues:
Could a charged PB attract a neutral object (one with no net charge)? If so, how could you check if an object is neutral?
Is it possible to get a misleading result? E.g. a positively charged object attracting a positively charge PB?
[Minor edits made]
What will the pith ball be attracted or repulsed by?
I note it mentions the "nature" of the charge. If that means positive or negative then I don't think that a standard gold leaf electroscope can do that.
If the gold leaf electroscope is given a prior net charge (of known sign) the leaves will diverge and remain so.
Then a charged object is brought near to the cap.
There will be either an increase or a decrease in the divergence of the leaves, depending on the sign of the object's charge.
I've never actually done it, but it should work.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
