Describe the position of a pulley attached to a sling
In summary, the floating pulley changes its position depending on the force applied to the cable at the drum.
  • #36
haruspex said:
I meant to write
OK, I see
  • #37
haruspex said:
I meant to write
But then there are still two unknowns, namely θ and φ.
  • #38
Doesn’t matter. At this stage we are just trying to find a relationship between them. Next step will be to involve them in force balance equations.
In fact, if you are stuck on getting that relationship, set that aside and move onto the other equations.
  • #39
Alright I'll try to find the relationship then.
  • #40
Still stuck on finding the relationships :(
  • #41
Now I have that: AD2=AC2+CD2-2*AC*CD*cos(γ-θ), with γ the angle ∠ACB. But still don't understand the force balance equations
  • #42
Been a while. Remind us what force balance equations you have gathered so far and which one you don't understand :wink:
  • #43
Was on holiday ;) , I just don't understand how I can solve this problem when there are more than one unknowns
  • #44
First, find all the angles of triangle ACD in terms of α, θ, φ.
  • #45
Does this make sense?
  • #46
Need more?
  • #47
And I have that: BD2=AB2+AD2-2*AB*AD*cos(α2) when you substitute AD from the earlier post in this equation then you have an equation to solve α2 with θ as unknown and α2 is equal to α-(180-90-φ). So I can express θ in φ
  • #48
Jeroen Staps said:
That’s good. You know the lengths of two sides of ACD. What equation can write connecting those with two of its angles?
  • #49
I now have the following equation that seems to be correct:
φ = cos-1((AC-CD*cos(γ-θ)) / √(AC2+CD2-2*AC*CD*cos(γ-θ))) + 90 - α
  • #50
But how do I use this to describe the location of D when there is a certain mass hanging at D and there is a certain pulling force in AD?
  • #51
I was thinking of something simpler, though it may be equivalent: the sine rule.
  • #52
As I posted, you can use angles θ and φ to write a force balance equation.
  • #53
I used the cosine rule twice to come up with this
  • #54
So does my post #45 make sense?
  • #55
Yes, at least for equilibrium. Adding constant acceleration should be easy.
But I wished you wouldn't change notation every time.
And you can easily simplify ##\ \sin(\pi/2-\pi/4-\phi)\ ## and ##\ \cos(\pi/2-\pi/4-\phi)\ ## I should hope.
So how many equations with how many unknowns do you now have altogether ?
  • #56
I believe it is a statics question, how the equilibrium position depends on the applied tension.
  • #57
The question is: What is the position of the pulley when there is a given mass of the load and a given ratio between the force of gravity and the pulling force.
  • #58
Which is the same as I wrote.
