What is the definition of center of mass?
In summary: R## is the resultant (external) torque about the center of mass, and ##r## is the distance from the center of mass.
Bashyboy
1,421
Hello,
I am trying to describe the concept of center of mass, and need some help with particulars:
The center of mass can be thought of the balancing point of a body; it is the point where mass is "evenly distributed" with respect to this point, such that if you were to place the body in a gravitational field and balance on its COM, then the gravitational force acting on each constituent mass would all cancel each and not produce a torque.
The idea I am having most difficulty reconciling is the idea that the mass is "evenly distributed." What is a better description for this, but keeps the same general idea.
Center of mass does not (cannot) depend on even mass distribution since if it did ONLY very regular bodies could have a center of mass, which is silly.
I don't know how to describe it formally, but here's how I think of it. If the body in question is assumed to be rigid (and if it isn't, you can get a shifting center of mass), AND you could magically attach something to the center of mass (that magically moves freely OTHER than being attached to the center of mass), then there is no orientation such that the body hanging from the connection to the center of mass would, in a uniform gravitational field, shift from that orientation due to gravity.
I guess what I mean by evenly distributed is this: suppose we have a long, thin rod; if you were to divide the rod at its center of mass, each piece of the rod would have the same mass. This idea works for two dimensional objects, I am having difficulty extending it to three dimensional objects.
That's true for a uniform rod. What about two unequal balls connected by a thin rod?
Hmm, if you were to divide the thing rod at its center of mass, each piece would be unequal in mass.
Right. So thinking the mass would be "evenly distributed" won't work.
As you already pointed out, you want the distribution such that the net torque about the COM is zero. That's equivalent to saying that the mass-weighted average position of the mass elements would be at the COM.
A hypothetical particle that when the sum of the external forces on the system is zero will constitute an inertial frame (will travel in a straight line with respect to a lab frame or be at rest for all time with respect to a lab frame). This is the intuitive notion of the center of mass that I have personally found the most useful when solving problems in which the center of mass frame becomes invaluable e.g. two body problems interacting under some potential.
Formally it is simply ##R = \frac{1}{\int dm}\int rdm##.
Related to What is the definition of center of mass?
1. What is the center of mass?
The center of mass is the average location of the mass of an object. It is the point where the entire mass of the object can be considered to be concentrated.
2. How is the center of mass calculated?
The center of mass is calculated by finding the weighted average of the positions of all the particles that make up an object. This takes into account both the mass and the position of each particle.
3. Why is the center of mass important in physics?
The center of mass is important in physics because it helps describe the motion and stability of an object. It is also used in calculations for forces, such as torque and gravitational attraction.
4. Can the center of mass be outside of an object?
Yes, the center of mass can be outside of an object. This is possible when the object has an irregular shape or when the mass is distributed unevenly within the object.
5. What is the difference between center of mass and center of gravity?
The center of mass is the average location of the mass of an object, while the center of gravity is the point where the force of gravity on an object can be considered to act. For most objects on Earth, the center of mass and center of gravity are in the same location, but for objects in space or with varying gravitational fields, they may differ.
