evinda
MHB
- 3,836
Hello! (Wave)
I am looking at the description of the Simplex algorithm.Let $\overline{x_0}$ be a non degenerate basic feasible solution.
We suppose that $\overline{x_0}=(x_{10}, x_{20}, \dots, x_{m0},0, \dots,0)$ with $x_{10}, x_{20}, \dots, x_{m0}>0$.
Thus the first $m$ columns of $A$, i.e. $P_1, P_2, \dots, P_m$ are linearly independent (so they are a basis of $\mathbb{R}^m$).
Thus for each $j$ it holds that $P_j= x_{1j}P_1+ x_{2j} P_2+ \dots + x_{mj} P_m$ for suitable $x_{1j}, x_{2j}, \dots, x_{mj} \in \mathbb{R} (1)$.
We know that $Ax_0=b \Leftrightarrow P_1 x_{10}+ P_2 x_{20} + \dots + P_{m0} x_{m0}=b (2)$
We fix a $j \in \{ m+1, \dots, n \}$.$$(2)- \theta (1), \text{ where } \theta \in \mathbb{R}:$$
$$(x_{10} - \theta x_{1j})P_1 + (x_{20}- \theta x_{2j}) P_2+ \dots +(x_{m0}- \theta x_{mj})P_m+ \theta P_j=b (3)$$
$(3) \Rightarrow \overline{x}(\theta)=(x_{10}- \theta x_{1j}, x_{20}- \theta x_{2j}, \dots, x_{m0}- \theta x_{mj},0, \dots,0, \theta, 0,0, \dots)$ is a solution of the system of restrictions ($A \overline{x}(\theta)=b$) In order to have $\overline{x}(\theta) \in F$ it has to hold
$$ x_{10} - \theta x_{1j}>0 , x_{20}- \theta x_{2j}>0 , \dots , x_{m0}- \theta x_{mj}>0, \theta>0 (4)$$We notice that for $\theta$ small enough, $(4)$ holds and so there are feasible solutions with $m+1$ non-zero coordinates.
So in order to find a new basic feasible solution we have zero one of the first $m$ coordinates of $\overline{x}(\theta)$ for an appropriate choice of $\theta$.
Then $\theta$ satisfies $(4)$ whenever $0< \theta< \theta_0$, where $\theta_0=\min_i \{ \frac{x_{i0}}{x_{ij}}: x_{ij}>0\}$.
We define $\theta=\theta_0$ an consider the corresponding vector $\overline{x}(\theta) \in F$.
Then one of the $m$ first components of $\overline{x}(\theta)$ is zero.
We suppose that $x_{10}- \theta x_{1j}=0$.
Then $\overline{x}(\theta)$ is a candidtae basic feasible solution and so that it is indeed such a solution , it suffices to show that $P_2, P_3, \dots, P_m, P_j$ are linearly independent.How can we show that $P_2, P_3, \dots, P_m, P_j$ are linearly independent?
If we suppose that $P_2, P_3, \dots, P_m, P_j$ are linearly dependent then there are $\lambda_2, \lambda_3, \dots, \lambda_m, \lambda_j \in \mathbb{R}$ with $|\lambda_2|+ |\lambda_3|+ \dots+ |\lambda_m|+ |\lambda_j| \neq 0$ such that
$$\lambda_2 P_2+ \lambda_3 P_3+ \dots + \lambda_m P_m+ \lambda_j P_j=0$$
We also know that $A \overline{x}(\theta)=b \Rightarrow P_2 (x_{20}- \theta x_{2j})+P_3 (x_{30}- \theta x_{3j})+ \dots+ P_m (x_{m0}- \theta x_{mj})+P_j \theta=b$
Can we find a contradiction from these two relations? Or do we have to use something else? (Thinking)
