Designing a power supply with a center tapped-transformer and a zener diode.
In summary, the project aims to create a full-wave regulated power supply that can provide a constant 7.5 V to a load varying from 120 to 450 . The power supply must rectify the secondary current and provide a stable output voltage.
kaichie
Design a full-wave regulated power supply using a 5:1 center-tapped transformer and a 7.5 V, 1 W Zener diode. The power supply must provide a constant 7.5 V to a load varying from 120 to 450 . The input voltage is 120 V(rms), 60HZ.
http://s1233.photobucket.com/albums/ff382/chie8/?action=view&current=asd.png
The oscilloscope shows no voltage drop across the 7.5V zener diode.
I think you'll want to rectify the secondary current -- a diode in each of the two outer legs of the transformer secondary to provide full wave rectification. Also, you should stick a load resistance on the circuit output where you have your 'scope' in order to simulate the desired load. Maybe start with a maximum load (so the current drawn would be 450 mA if the supply provided 7.5V DC. Then take a look at your output and see what else you might need to do.
Your diagram unfortunately shows the xfmr secondary being short-circuited! Lotsa smoke, maybe. Not good smoke like pipe tobacco, either.
As gneill says, put diode in each secondary leg (not the center-tap). Cathodes connected together, anodes to each secondary high (pointing to the right). Then, the 100 ohm CT resistor is too big - at max output current = 7.5V/120 = 62.5 mA, the CT voltage is already at - 6.25V so each secondary high winding can't go above -6.25 + 115/(2*5)V. Moreover, these voltages are squirrely - combination of sine and chopped-off full-wave rectified sine.
I would ground the CT and move R to between the diode cathodes and your zener/resistive load. To avoid overheating the zener, 7.5*(11.5-7.5)/R = 1W. This limits the zener to 1W peaks in the no-load condition.
Unfortunately, your output voltage will not be constant; the zener will not always be turned on. To achieve that goal, you need a capacitor shunting your load. I would guess RC = 8ms with worst-case R = 120 so C = 68uF. This would be a polarized cap so make sure you get the + end on the output & the - end to ground, not vice-versa.
FAQ: Designing a power supply with a center tapped-transformer and a zener diode.
1. What is a center tapped-transformer and how does it work?
A center tapped-transformer is a type of transformer that has a wire connected to the center of the secondary winding. This center tap divides the secondary winding into two equal parts. It works by stepping down the voltage from the primary winding and providing two equal and opposite voltages in the secondary winding.
2. What is the purpose of using a center tapped-transformer in a power supply?
The purpose of using a center tapped-transformer in a power supply is to provide a split supply, where the positive and negative voltages can be used separately. This is useful for applications that require both positive and negative voltages, such as in audio amplifiers.
3. What is a zener diode and why is it used in a power supply with a center tapped-transformer?
A zener diode is a type of diode that is designed to operate in the reverse breakdown region, meaning it can maintain a constant voltage across its terminals. It is used in a power supply with a center tapped-transformer to regulate the output voltage and protect the circuit from overvoltage.
4. How does a zener diode regulate the output voltage in this type of power supply?
A zener diode is connected in parallel with the load in a power supply with a center tapped-transformer. As the load draws current, the voltage across the zener diode remains constant, thus regulating the output voltage. If the output voltage increases beyond the breakdown voltage of the zener diode, it will start conducting and limit the voltage to its rated value.
5. Are there any limitations to using a center tapped-transformer and a zener diode in a power supply?
Yes, there are some limitations. The main limitation is that the output voltage cannot be adjusted or varied. It will always be equal to the breakdown voltage of the zener diode. Additionally, the zener diode has a maximum current rating and exceeding this rating can cause it to fail. It is important to choose a zener diode with a suitable breakdown voltage and current rating for the specific application.
