martinlematre
- 41
You’re given a 12.0V battery, 3 light bulbs (of 10.0Ω each), and LOTS of 10.0Ω resistors. Make a circuit so that the light bulbs’ brightnesses are multiples of 1, 2, 3. In other words, if the dimmest light bulb has brightness B, the second dimmest will have brightness 2B, and the brightest will be 3B.
I've derived a few over a few hours and have drawn it out and mapped and graphed v^2/r (I'm assuming in this case brightness means POWER which is vsquared over r)
I just don't see how this is possible to actually map out these 10 ohm resistors with a 10 ohm bulb and a set 12 volt battery. I am under the presumption that by brightness my teacher means power, and having graphed the voltages after crossing a list of quantities of 10 ohm resistors, I cannot find 3 powers that are direct multiples of 2 and 3 of one resistor configuration.
Note that there is no statement for what we are defining as brightness, we have not been taught anything about brightness and that's actually the first time the word has popped up in this course. I don't understand because under my understanding, anything you can construct on a resistor circuit is not linearly related to the brightness, but rather the measurement of lumens of the bulb. Would appreciate if anoyne helped
