C/C++ Detecting First Letter Match in C++ String with Substr Function
  • Thread starter Thread starter ineedhelpnow
    C++ String
To detect if the first character of `userInput` matches `firstLetter`, the expression should compare the first character of the string directly. The correct approach in C++ involves using indexing to access the first character of `userInput`. The expression can be written as `userInput[0] == firstLetter`. The discussion highlights the confusion around using the `find` method and the `substr` function, clarifying that `find` is not suitable for this task since it searches for a character within the string rather than checking the first character. The `substr` function is also mentioned, but it is unnecessary for this specific comparison. Instead, simply accessing the first character with `userInput[0]` provides a straightforward solution.
ineedhelpnow
Write an expression to detect that the first character of userInput matches firstLetter.
Sample program:
Code:
#include <iostream>
#include <string>
using namespace std;
int main() {
   string userInput;
   char firstLetter = '-';
   userInput = "banana";
   firstLetter = 'b';
   if (<STUDENT CODE>) {
      cout << "Found match: " << firstLetter << endl;
   else {
      cout << "No match: " << firstLetter << endl;
   return 0;
i tried userInput.find(firstLetter, 1) but it only partially passed
Technology news on Phys.org
Okay, we know the [m]str.substr(pos,len)[/m] method in C++ will return from the string [m]str[/m], the sub-string beginning at position [m]pos[/m] and spanning length [m]len[/m].
So, we want to see if the first character of the string [m]userInput[/m] matches the value of [m]firstLetter[/m].
First, what values of [m]pos[/m] and [m]len[/m] do we want?
um Mark...are you sure this is c++ you're talking about? (Blush) I've never heard of those commands before.
You told me that you are familiar with the [m]substr()[/m] function. You will replace [m]str[/m] with [m]userInput[/m] since this is the name of the string from which you wish to extract the first character. I was just giving you the general usage. You will also need to determine what values you need for the parameters [m]pos[/m] and [m]len[/m].
ive never heard of pos and lens before i meant.
They are just placeholders for the two parameters that the [m]substr()[/m] function expects. For example, if I have a string [m]str = "Hello!";[/m], then [m]str.substr(1,2)[/m] will return "el" because we start at position 1 (the second character) and are getting 2 characters.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
34K
