Detecting induced electric fields in the ocean
In summary: Yes, this is an interesting idea and the application of measuring fluid motions by monitoring the electric fields of ions in the fluid is a good one.
royzizzle
50
Hi everyone:
Since there are many ions in ocean water, and these ions are carried by ocean currents, and they are moving through the Earth's magnetic field, by the electromagnetic induction laws, wouldn't there be a induced electric field in the ocean?
if i want to detect this electric field, would all i need be a piece of conducting wire connected to a very sensitive voltmeter and then place it in the ocean?
p.s: couldn't this be used as a very sensitive tsunami detector? when a tsunami wave passes through, there would be an increase int the speed of conductors.
No.
An interesting idea, but there are equal numbers of positive and negative ions in sea water, so any effects would cancel out.
here is the composition of seawater according to wikipedia:
Component Concentration (mol/kg)
H2O 53.6
Cl− 0.546
Na+ 0.469
Mg2+ 0.0528
SO2−
4 0.0282
Ca2+ 0.0103
K+ 0.0102
CT 0.00206
Br− 0.000844
BT 0.000416
Sr2+ 0.000091
F− 0.000068
from inspection, it can be seen that seawater has slightly more negative ions than positive.
edit: more positive than negative, but only a small amount: .00227moles/kg
The main salt in sea water is Sodium Chloride which dissociates as follows:
NaCl → Na + + Cl -
giving equal numbers of positive and negative ions.
The other salts do the same thing when they dissociate.
There may be more Cl - ions because more than one Chloride formed the original salt mixture.
The list doesn't give H + and OH - ions which would be considerable unless the seawater was completely neutral.
royzizzle, measuring fluid motions by monitoring the electric fields of ions in the fluid seems like a good idea. The charged particles do move through the earth’s magnetic field and, of course, they do obey induction laws. Using the basic laws of physics to create measuring devices is always a sure path to new and innovative ideas.
As for a tsunami detector, this mechanism probably would not be viable. If the sensitive voltmeter was immersed in the ocean to measure fluid motion it may be difficult or impossible to discriminate between normal ocean waves and a passing tsunami wave. Here are a few excerpts from the Wiki tsunami page:
“Tsunami waves do not resemble normal sea waves, because their wavelength is far longer. Rather than appearing as a breaking wave, a tsunami may instead initially resemble a rapidly rising tide, and for this reason they are often referred to as tidal waves. Tsunamis generally consist of a series of waves with periods ranging from minutes to hours, arriving in a so-called "wave train".[4]
Tsunamis have a small amplitude (wave height) offshore, and a very long wavelength (often hundreds of kilometers long, whereas normal ocean waves have a wavelength of only 30 or 40 metres),[22] which is why they generally pass unnoticed at sea, forming only a slight swell usually about 300 millimetres (12 in) above the normal sea surface. They grow in height when they reach shallower water, in a wave shoaling process described below. ”
http://en.wikipedia.org/wiki/Tsunami
Now, it may be useful to read up on how tsunami warning systems are now being implemented around the world. Basically, they measure the increase in pressure caused by the passing tsunami wave using sensors on the sea bottom. See:
http://www.tsunami.noaa.gov/warning_system_works.html
http://nctr.pmel.noaa.gov/Oceans99/index.html
http://www.ndbc.noaa.gov/dart/dart.shtml
Observation: Maybe your basic idea of measuring ionic motion would find useful applications in biomedicine where measuring blood and urine flows is important. And what about in neuroscience, where minute ionic charges are moving around our nervous systems and inside our brains? I hope you are keeping a notebook with your ideas.
FAQ: Detecting induced electric fields in the ocean
How are induced electric fields detected in the ocean?
Induced electric fields in the ocean are typically detected using specialized instruments called magnetometers, which measure changes in the Earth's magnetic field caused by the flow of electric currents in the ocean. These instruments are usually towed behind a ship or mounted on a submarine.
What causes induced electric fields in the ocean?
Induced electric fields in the ocean are caused by the interaction between the Earth's magnetic field and the movement of seawater. This movement can be caused by tides, ocean currents, or even disturbances such as underwater earthquakes.
How do induced electric fields affect marine life?
The effects of induced electric fields on marine life are not fully understood, but they are thought to play a role in the navigation and behavior of certain species, such as sharks and sea turtles. These fields may also have an impact on smaller organisms like plankton, which can be negatively affected by changes in their environment.
Can induced electric fields be harmful to humans?
Induced electric fields in the ocean are not known to be harmful to humans. However, in some cases, strong electric fields near underwater power cables or other man-made structures may pose a risk to divers or other individuals in close proximity.
How do scientists use data from induced electric fields in the ocean?
Scientists use data from induced electric fields in the ocean to better understand the behavior of the Earth's magnetic field and the movement of seawater. This information can also be used to study ocean currents, tides, and other important aspects of our planet's ocean systems.
