Detecting Interference Patterns with Large Objects: The Double Slit Experiment
In summary, the Heisenberg Uncertainty Principle states that when measuring the position of a particle, there will be an inherent uncertainty in its velocity. This applies to larger objects as well, making it difficult to detect interference patterns in the double slit experiment with objects like bacteria. The largest objects that have been successfully used in the experiment were molecules consisting of 810 atoms.
john taylor
24
Why is it so difficult to detect interference patterns with larger objects in the double slit experiment(e.g. bacteria)?
One way to look at it is to use the Heisenberg Uncertainty Principle for the y-direction is:
##\sigma_y \sigma_p \ge \frac{\hbar}{2}##
If we define the y-velocity as ##v = \frac{p}{m}##, then we have:
##\sigma_v \ge \frac{\hbar}{2m} \sigma_y##
If ##m## is large, then you have very little uncertainty in the y-velocity of the particle. Effectively, you have a classical trajectory through the slit.
For an electron, ##m## is relatively small, so you get a larger uncertainty in the y-velocity, which is necessary for the interference pattern to emerge.
Note that this applies equally to single-slit experiments.
what would it take to replicate the double slit experiment with larger objects such as microorganisms?
You can't. They are just too big. According to Wikipedia:
The experiment can be done with entities much larger than electrons and photons, although it becomes more difficult as size increases. The largest entities for which the double-slit experiment has been performed were molecules that each comprised 810 atoms (whose total mass was over 10,000 atomic mass units).[1][2]
Likes bhobba
Related to Detecting Interference Patterns with Large Objects: The Double Slit Experiment
1. What is the double slit experiment?
The double slit experiment is a classic physics experiment that demonstrates the wave-particle duality of light. It involves shining a beam of light through two parallel slits and observing the resulting interference pattern on a screen.
2. How does the double slit experiment demonstrate wave-particle duality?
The double slit experiment shows that light behaves both as a wave and as a particle. When the light passes through the slits, it creates an interference pattern, which is characteristic of waves. However, when the light is observed at the screen, it appears as individual particles or photons.
3. Can the double slit experiment be performed with large objects?
Yes, the double slit experiment has been successfully performed with large objects such as buckyballs (molecules made up of 60 carbon atoms). This demonstrates that the wave-particle duality is not limited to light, but can also be observed in larger objects.
4. What happens when larger objects are used in the double slit experiment?
When larger objects are used in the double slit experiment, the interference pattern becomes more blurred and less distinct. This is due to the fact that larger objects have a higher mass and are affected by external factors such as air resistance and gravity, which can disrupt the interference pattern.
5. Why is the double slit experiment important in science?
The double slit experiment is important in science because it provides evidence for the wave-particle duality of matter and light. It also challenges our understanding of the fundamental nature of reality and has implications for fields such as quantum mechanics and particle physics.
  • Quantum Physics
  • Quantum Physics
