Detecting Multiple Planets Around a Star
In summary, the radial velocity method assumes that the orbital period of the star's planetary companion is equal to the period of the star's detected wobble. If a star has multiple planets in orbit around it, then it is possible to detect something other than Jupiter using the radial velocity method. The Doppler wobble from the first planetary candidate gives an approximate orbit. Further observations improve the estimate. Later observations show that the first planet is running a bit faster then a bit slower than its predicted motion. Back-calculating these 'residuals' give an estimate for a second planet. Further measurements improve the estimate until new, cyclic 'residuals' appear.
cepheid
Staff Emeritus
38
In the Doppler shift or radial velocity method for detecting exoplanets, it is assumed that the orbital period of the star's planetary companion is equal to the period of the star's detected wobble. I'm assuming that this fact comes straight from the solution to the two-body problem.
My question is, what if a star has multiple planets in orbit around it? Say, for example, we were viewing our solar system from afar. Would we be able to detect anything other than Jupiter? I guess this is an n-body problem, although it seems that the typical thing to do is to assume that the interaction between each planet and the parent star is much greater than the interactions among planets, which can be ignored. So, I guess that this is like 8 independent two-body problems, each of which gives a solution that is a good (zeroth-order? first-order?) solution for that planet's orbit.
What's confusing me is that the solution to each two-body problem would have you believe that the parent star wobbles with a period equal to the orbital period of the second object. So, how could the sun wobble "around" the barycentre on 8 different timescales? What does the wobble look like if there are multiple planets, and how are we supposed to know that they are there?
Astronomy news on Phys.org
IIRC, the way it is done is to look for 'residuals': The Doppler wobble from the first planetary candidate gives an approximate orbit. Further observations improve the estimate. Later observations show that the first planet is running a bit faster then a bit slower than its predicted motion. Back-calculating these 'residuals' give an estimate for a second planet. Further measurements improve the estimate until new, cyclic 'residuals' appear...
Interesting! Thanks Nik_2213 and Nabesin for the verbal and visual help, respectively.
I can provide some clarification on this topic. First, it is important to note that the Doppler shift or radial velocity method is just one of several techniques used to detect exoplanets. Other methods include the transit method, direct imaging, and gravitational microlensing.
In the Doppler shift method, the assumption that the orbital period of the star's planetary companion is equal to the period of the star's detected wobble is based on the two-body problem solution. This is a simplified assumption and may not accurately represent the complex dynamics of a multi-planet system.
In reality, a star with multiple planets will exhibit a more complex wobble pattern, with each planet contributing to the overall motion of the star. This can make it more challenging to accurately detect and characterize each individual planet.
However, with advanced techniques and technology, it is possible to detect multiple planets around a star. For example, the use of high-resolution spectroscopy can help distinguish between the different signals from each planet and provide more detailed information about their orbits.
Additionally, the presence of multiple planets can also affect each other's orbits, causing slight variations in their respective periods and wobble patterns. These effects, known as transit timing variations and radial velocity variations, can provide clues to the presence of multiple planets in a system.
In summary, while the Doppler shift method may make simplified assumptions about the dynamics of a multi-planet system, there are other techniques and advanced technologies that can help detect and characterize these systems. It is an ongoing and exciting area of research in the field of exoplanet detection and study.
Related to Detecting Multiple Planets Around a Star
1. How do scientists detect multiple planets around a star?
Scientists use a variety of methods to detect exoplanets (planets outside of our solar system) around a star. One of the most common methods is called the radial velocity method, which measures the slight wobble of a star caused by the gravitational pull of orbiting planets. Another method is the transit method, which looks for dips in a star's brightness as a planet crosses in front of it.
2. Can we detect all planets around a star?
No, currently we can only detect planets that are large enough and close enough to their star to affect its movement or cause a dip in its brightness. This means that smaller or more distant planets may go undetected.
3. How long does it take to detect multiple planets around a star?
The time it takes to detect multiple planets around a star varies depending on the detection method, the size and distance of the planets, and the technology being used. In some cases, it can take several years of observation to confirm the presence of multiple planets.
4. How can we determine the characteristics of these planets?
Scientists can use various techniques to determine the characteristics of the planets, such as their size, mass, and distance from their star. This can include analyzing the star's light spectrum, measuring the timing and duration of transits, and studying the gravitational influence on the star.
5. Why is detecting multiple planets around a star important?
Detecting and studying multiple planets around a star can give us valuable insights into how planetary systems form and evolve. It can also help us understand the diversity of planets in our universe and increase our chances of finding habitable exoplanets. Additionally, detecting multiple planets can help us refine our methods for detecting and studying exoplanets, leading to further advancements in the field of exoplanet research.
