RobikShrestha
- 37
- 1
I am referring to an experiment mentioned in Quantum Entanglement lecture:
(Starting from: 14:20)
In that lecture, as far as I understand, the description of the experiment is as follows:
Assume:
"up state" means north pole is vertically upwards
1. Preparing the state: Prepare electron to be in certain state (an arbitrary angle) by placing it in a magnetic field at certain angle.
2. Turn off that magnetic field.
3. Detecting the state: Turn on another magnetic field to detect the state of the electron. The north pole of external magnet is vertically downwards and the south pole is vertically upwards. Detect the state of the electron's state (up or down) by detecting if the electron releases any photon or not. If the electron releases photon, then it is "concluded" that previously, the electron had its north pole downwards i.e. electron was in "down" state. If electron does not emit any photon, then it is assumed that previously it was in "up" state. That "photon" released always has same energy (which is equal to energy released when transitioning from "down" to "up"). This is true even in cases where electron has been prepared in some other angle (i.e. neither down nor up but something in between).
The argument made here is that, no matter what "state" (angle) the electron is prepared for (in step 1), while "detecting the state" we find that either electron releases no energy or some constant energy. So "detecting the state" results in either "up" or "down", but not any other state.
But just because electron emits constant energy (equal to transition from down to up), why should it be "concluded" that it was previously "down"? May be the photon has quantized energy, so no matter what state it previously was in, it always releases that particular amount of energy to get to state "up".
My question is: is it correct to assume electron was previously "down" just because it releases that particular amount of energy (equal to transitioning from down to up) to go to state "up"?
Assume:
