Detecting the Earth's magnetic field
In summary, the conversation discusses the possibility of building a solar storm detector to detect the effects of solar wind on the Earth's magnetic field. The suggested detector would run continuously for a couple of weeks to capture small fluctuations in the magnetic field. It is mentioned that the net field is around 10 uT and variations in the ionosphere can cause noticeable changes. The conversation also references the electric currents induced in the ionosphere and their effects on the Earth's magnetic field.
Steel_Panther
Hi guys just a quick question.
I was thinking of building a fairly simple solar storm detector, something similar to this
http://aurorawatch.lancs.ac.uk/detectors/compass
I was just wondering if the effects that the solar wind has on the shape of the Earth's magnetic field, such as the compression it experiences on the side facing the sun and the extension on the opposite side, could be detectable.
I was thinking of running the detector continuously for a couple of weeks to try to detect small fluctuations in the Earth's magnetic field, and then compare the captured data for the day and night.
Thanks a lot
You'd be able to capture these effects I'm sure. The net field is about ~10 uT but variations in the ionosphere and such should cause some noticeable changes. It'd be interesting to see what results you get.
Per wiki: http://en.wikipedia.org/wiki/Earth's_magnetic_field#Currents_in_the_ionosphere_and_magnetosphere
Electric currents induced in the ionosphere generate magnetic fields (ionospheric dynamo region). Such a field is always generated near where the atmosphere is closest to the Sun, causing daily alterations that can deflect surface magnetic fields by as much as one degree. Typical daily variations of field strength are about 25 nanoteslas (nT) (one part in 2000), with variations over a few seconds of typically around 1 nT (one part in 50,000).[52]
Related to Detecting the Earth's magnetic field
1. How do we detect the Earth's magnetic field?
We use a device called a magnetometer, which measures the strength and direction of the magnetic field.
2. What causes the Earth's magnetic field?
The Earth's magnetic field is caused by the movement of molten iron in its outer core. This creates electric currents, which in turn generate the magnetic field.
3. How does the Earth's magnetic field protect us?
The Earth's magnetic field acts as a shield, deflecting harmful solar winds and cosmic radiation away from the planet.
4. Is the Earth's magnetic field constant?
No, the Earth's magnetic field is not constant. It has been weakening over time and also experiences periodic reversals, where the magnetic poles switch places.
5. Can we see the Earth's magnetic field?
No, the Earth's magnetic field is invisible to the naked eye. However, we can see its effects, such as auroras, which are caused by charged particles interacting with the magnetic field.
  • Astronomy and Astrophysics
