Determinant formula with Einstein notation proof
In summary, the conversation discusses the task of proving that the determinant of a second order tensor is equal to a specific formula, and suggests using the definition of the determinant to do so.
Mugged
104
Hello, I am supposed to prove that the determinant of a second order tensor (a matrix) is equal to the following:
det[A] = [tex] \frac{1}{6} \epsilon_{ijk} \epsilon_{pqr} A_{pi} A_{qj} A_{rk} [/tex]
anyone have any idea how i would go about this? any method is welcome
where the determinant of the matrix A is expressed below:
det[A] =
[tex] A_{11}(A_{23}A_{32}-A_{22}A_{33}) + A_{12}(A_{21}A_{33}-A_{23}A_{31}) + A_{13}(A_{22}A_{31}-A_{21}A_{32}) [/tex]
Assuming that last formula is your definition of the determinant, then the obvious way to do this is to write out the actual sum implied by the first formula and show that the two formulas are the same thing.
Related to Determinant formula with Einstein notation proof
1. What is the determinant formula with Einstein notation proof?
The determinant formula with Einstein notation proof is a mathematical formula that allows you to find the determinant of a matrix using Einstein summation notation. It is a concise and elegant way of representing the determinant, which is a value that describes the relationship between the rows and columns of a square matrix.
2. How is the determinant formula with Einstein notation proof derived?
The determinant formula with Einstein notation proof is derived from the more traditional formula for finding the determinant of a matrix. It involves using the properties of determinants, such as linearity and the alternating property, and converting them into Einstein summation notation. This allows for a more compact and efficient representation of the determinant.
3. What are the benefits of using the determinant formula with Einstein notation proof?
The determinant formula with Einstein notation proof has several benefits. It is more concise and easier to write compared to the traditional formula. It also allows for the use of matrix manipulations, such as transposes and inverses, making it more versatile. Additionally, using Einstein notation can help simplify complex calculations and make them easier to understand.
4. Are there any limitations to using the determinant formula with Einstein notation proof?
While the determinant formula with Einstein notation proof has many advantages, it also has some limitations. It is only applicable to square matrices, and it can be challenging to understand for those who are not familiar with Einstein notation. Additionally, it may not be the best method for calculating determinants for large matrices with many elements.
5. How can I learn more about the determinant formula with Einstein notation proof?
If you are interested in learning more about the determinant formula with Einstein notation proof, there are many online resources and textbooks available. You can also consult with a math tutor or professor who can provide further explanations and examples. Practicing with different matrices and working through problems can also help improve your understanding of this concept.
