Determinant of a Unitary Matrix
In summary, for a unitary matrix U, it can be shown that for all vectors x, the magnitude of Ux is equal to the magnitude of x. This can be proven by using the fact that U^H=U^{-1} and the property that |a|=aa^H.
thepopasmurf
76
Let U be a unitary matrix. Show that for all vectors x that
|Ux| = |x|
[tex]U^H=U^{-1}[/tex]
[tex]|Ux|=|U||x| [/tex]
[tex] U^HU=I [/tex]
[tex] |U^HU|=1[/tex]
[tex] |U^T|^*|U|=1 [/tex]
[tex] (det(U))^2 = 1 [/tex]
so
det(U) = +/- 1
But that doesn't solve the question
First, convince yourself that [itex]|a|=aa^H[/itex]. Then use this to calculate |Ux| and |x|.
Hang on, the vertical bars are standing for the magnitude, not the determinant? I need to do this all again.
Uh, well, if they mean determinant, then I have no idea what |x| would mean. You can't take the determinant of a vector...
FAQ: Determinant of a Unitary Matrix
What is a unitary matrix?
A unitary matrix is a type of square matrix that is defined as a matrix whose conjugate transpose is equal to its inverse. This means that when you multiply a unitary matrix by its conjugate transpose, the result will be the identity matrix. In other words, the columns of a unitary matrix are orthonormal, meaning they are mutually perpendicular and have a magnitude of 1.
What is the determinant of a unitary matrix?
The determinant of a unitary matrix is always a complex number with a magnitude of 1. This is because the determinant of a matrix is equal to the product of its eigenvalues, and for a unitary matrix, the eigenvalues all have a magnitude of 1. Therefore, the determinant of a unitary matrix is always equal to either 1 or -1.
How is the determinant of a unitary matrix calculated?
The determinant of a unitary matrix can be calculated using the following formula: det(A) = e, where e is the base of the natural logarithm and θ is the sum of the angles of the eigenvalues. Alternatively, you can also calculate the determinant by multiplying the eigenvalues of the matrix together.
What are the properties of a unitary matrix?
Some of the key properties of a unitary matrix include:
  • Its columns are orthonormal, meaning they are mutually perpendicular and have a magnitude of 1.
  • Its rows are also orthonormal, since the conjugate transpose is equal to the inverse.
  • It preserves the length of vectors, as the magnitude of a vector is not changed when multiplied by a unitary matrix.
  • It preserves the angle between two vectors, as the dot product of two vectors is not changed when multiplied by a unitary matrix.
How is a unitary matrix used in applications?
Unitary matrices have many applications in mathematics and physics, particularly in the fields of quantum mechanics and signal processing. They are used to represent rotations and reflections in Euclidean space, and they also have important applications in the study of quantum systems and quantum computing. In addition, unitary matrices are used in data compression and error correction algorithms, making them an important tool in modern technology and communication systems.
