Determination of delivery pressure from pump
In summary, we need to determine the pressure in the delivery line of our centrifugal pump. We have a pressure gauge reading that is lower than what we anticipate from a 5hp pump. When we block the line just before the manifold, the gauge shows a reading of 3.5-4 kg/cm2. We need to plot the pump curve and add the nozzle flow curve to it in order to determine the pump's maximum delivery rate regardless of head.
kunalvanjare
80
We want to know how can we determine the pressure of the liquid at the delivery end of the pump. We have a centrifugal pump and a 2" pipeline at the delivery end. Pump delivery performance as per catalog is 510LPM @20 mtr head to 348LPM @36mtr head.
The delivery pipe is connected to a manifold on which spray nozzles are connected around 70 Nos.
The total length of pipe from the pump outlet to the spray manifold will be approx 5 metres of which 1.5mtr is vertical & remaining horizontal.
We have mounted a pressure gauge on the line which gives a constant reading of 0.6-0.8 Kg/cm2 which is lower is lower than our expectations from a 5HP pump.
Kindly help us determine the process of finding out the pressure in the line.
Also, If I have to select a pump that constantly delivers liquid at 3 Kg/Cm2, how do I go about the selection?
We need a system diagram that shows length and diameter of the piping, and elevations of the pressure gauge and the free surface of whatever you are pumping from. Also, what is the liquid? If not water, we need specific gravity and viscosity. If water, what is the temperature? What is the make and model number of the spray nozzles, or their rated pressure vs flow rate.
Likes russ_watters
Thanks for the reply. I have enclosed a schematic of the process with relevant dimensions.
In brief,
Diameter of the pipe - 50mm or 2"
Elevation of pressure gauge from ground - 1700mm
Length of pipe - mentioned in diagram
Liquid - Water
Temperature - 60-70 degree Celsius
Nozzle Rated pressure - 2 Bar @ 10 LPM
Total no. of nozzles - Approx 80
The pump characteristics are also enclosed in an image. The one marked in red is the pump I am using.
Thanks.
Some quick calculations: 80 nozzles X 10 LPM = 800 LPM at 2 bar = about 2 kg/cm^2.
You can take it from here with the following suggestions:
1) Plot the pump curve (hand sketch is good enough) with flow on the horizontal axis and TDH (head) on the vertical axis.
2) Nozzle flow is proportional to the square root of the pressure. Plot the nozzle flow curve on the pump curve.
Likes russ_watters
What is the pump's maximum delivery rate regardless of head?
Your question, and several other questions that you have not yet thought of, will be answered when you draw the pump curve, and add the nozzle flow curve to it. Post the curves here if you still have questions.
Likes Asymptotic
Related to Determination of delivery pressure from pump
What is the purpose of determining delivery pressure from a pump?
The purpose of determining delivery pressure from a pump is to ensure that the pump is functioning properly and delivering the desired amount of pressure to the intended location. This information is important for maintaining the efficiency and effectiveness of the pump's operation.
What factors affect the delivery pressure of a pump?
The delivery pressure of a pump can be affected by several factors, including the speed of the pump, the diameter and length of the discharge pipe, the viscosity of the fluid being pumped, and any pressure losses from friction or elevation changes.
How is delivery pressure measured from a pump?
Delivery pressure from a pump can be measured using a pressure gauge, which is typically connected to the discharge pipe. The gauge will display the pressure in units of force per unit area, such as pounds per square inch (PSI) or kilopascals (kPa).
Why is it important to accurately determine delivery pressure from a pump?
Accurately determining delivery pressure from a pump is important for ensuring the proper functioning of the pump and preventing damage to the pump and other equipment. It also allows for the efficient and effective delivery of fluids to their intended destination.
Can delivery pressure be adjusted on a pump?
Yes, delivery pressure can be adjusted on a pump by changing the pump's speed, adjusting the discharge pipe diameter or length, or using valves to regulate the flow. It is important to carefully adjust the pressure to avoid damaging the pump or causing other issues.
  • Mechanical Engineering
