A Determination of electron temperature in an ion source
The discussion focuses on determining the electron temperature in an ion source using the Electron Cyclotron Resonance (ECR) method. The Saha equation is proposed as a potential tool for this calculation, with the McWhirter criterion provided to assess its applicability. Participants seek clarification on the appropriate value of ΔE, which represents the energy gap for singly charged helium, to use in the formula. Understanding this value is crucial for accurate temperature determination. The conversation emphasizes the need for precise parameters to ensure reliable results in electron temperature calculations.
HeavyIon
How to correctly determine the temperature of electrons in an ion source based on ECR?
Is it possible to use the Saha equation?
##\frac{n_en_i}{n_a}=\frac{g_eg_i}{g_a}*3*10^{21} T^{3/2} e^{-J/T}##
Using the search, I found the McWhirter criterion for the applicability of the formula above:
##n_e >>1.6*10^{12}T^{1/2}*\Delta E^3##
Here ##n_e## is the electron density in ##cm^{-3}##, T is the electron temperature in ##eV##, and ##\Delta E## is the largest energy gap between upper and lower energy states that corresponds to one of the spectral lines used. I don't quite understand what \Delta E value should be considered in my case? I'm getting singly charged helium.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
