mstud
- 69
With a spectrometer we can see a black line in the spectrum of the sun at the angle [tex]\theta =20,73[/tex] from the maxima of 0. order. The line is in the maxima of the second order. Use the interference formula (given under heading 2) to determine the wavelength and color this line equals to. The used lattice has 300 lines / mm, that is d= 1mm/300.
[tex]dsin\theta =n\lambda[/tex] d is the distance between the lines in the lattice used,theta the angle from the zero-th maxima and n the order of the maxima in which the line is.
[tex]\lambda=\frac{\frac {1 \cdot 10^{-3} m}{300} \cdot sin (20,73)}{2}\approx 1,590 \cdot 10^{-6} m = 1590 nm[/tex]
The answer key of my book says 590 nm. And my answer even says that the radiation is infrared, so I must be wrong :-(
Does anybody see what's gone wrong here ? Thanks.
