Determine an expression for the period of motion.
borobeauty66
problem solved, thanks
borobeauty66 said:
...4Gπρ
F =−_______ mrrˆ (this second r^, being a unit vector)
...3
Fx = -kx
I'm not understanding the problem. You have the equation you need, just change r to x. What would k be?
The real question is: Can you solve it to find the period? (Compare it to the equations for simple harmonic motion.)
FYI: Writing your equations using Latex will make things easier:
F = - \frac{4G\pi\rho m}{3} r
Doc Al said:
What would k be?
k is the force constant.
Sure, so in your equation what would it be?
k = mω^2
We haven't been given the values for anything, we're supposed to find the expression in a format of algerbra only.
borobeauty66 said:
k = mω^2
That's the solution for the usual simple harmonic motion equation. Since your equation (for gravity) has the same form, it will have the same solution. Compare the two equations you wrote before: What will take the place of 'k' in your equation?
Right.
Right.
Do you mean F = -kx
and
k = mω^2
Therefore
F = -mw^2 x
borobeauty66 said:
Do you mean F = -kx
I mean to take that equation and compare it to the one you wrote for your gravity problem. What would be the equivalent to k?
OK give me a few minutes. I'm not very quite when it comes to rearranging and combing equations.
You shouldn't have to rearrange anything, just read it off.
Your equation has the form: Force = (some constant) x, what's that constant? (It's much easier than you think!)
I'm over-complcating things then?
I've just got to pop out anyway, so I'll have a think about it.
I'd say so. You know the solution for the standard SHM problem of a mass on a spring. So you want to compare the equations, since the same equations have the same solutions.
Not sure if my thinking is correct.
k = 4Gπρ/3
k = 4Gπρ/3
Almost! (You left out the mass.) But that's exactly the right idea.
Oh yes, mass sorry, so,
k = 4Gπρm/3
Ok, I'm with you up to hear, just unsure how this applies to period of motion, which is what the question asks for.
k = 4Gπρm/3
Well, what's the period for the standard SHM equation? (In terms of k.)
You mean the frequency? ω?
Well, you want the period. But you can express the period in terms of the frequency.
Oh I see, the period, t.
So, since ω = 2π/t
t =2π/ω (is this correct? as i say, I'm terrible as rearranging equations)
Not sure where to go from here.
So, since ω = 2π/t
Good.
Now use the expression for ω.
Hmmm, If I were to make F = -k x
into F= - mw^2 x
and then
F = -m (2π/t) x
and then rearrange to make t the subject, wouldn't this give me the period?
into F= - mw^2 x
and then
F = -m (2π/t) x
You forgot the square.
Lets keep it real simple. Forget your gravity problem for the moment. You have the SHM relationship F = -kx. Tell me the period in terms of k and m.
So, F = -k x
-k = F/x
That makes
-mw^2 = f/x
-w = square root of f/x +m
Am i going in the wrong direction?
borobeauty66 said:
So, F = -k x
-k = F/x
That makes
-mw^2 = f/x
Yes. You already have the solution. From post #5, solve for ω in terms of m and k. And then use what you told me in post #19 to get period in terms of ω and then m and k. When all is said and done, I want to see an expression for period in terms of m and k only.
Then all you have to do to apply this standard solution to your problem is to replace k by what you told me it equaled in post # 15.
OK,
so,
k = mω^2
ω = 2π/t = √k/m
2π/t = √k/m
makes
t=2π/√k/m
So replacing k
t = 2π/√(4Gπρm/3)/m
Good. Now simplify that as much as you can.
Now, there's a challenge!
Anyway, I think I got it from here (minus simplifying it) Many thanks for your help!
Good! And you're quite welcome.
Just realized that mass isn't part of the 4Gpi p/3 equation, it comes later. :-P
  • #31
Not quite sure what you mean. In any case, when you simplify your expression in post #25, the mass cancels out.
  • #32
What I mean is the equation give at the start is F = -(4Gpi p/ 3) m r r^
It's not that included in the brackets. So I suppose it's not included in the value of K
  • #33
This is the original equation.
I'm now wondering if
F = -k x is infact equal to the above?
  • #34
They both have the same form: Force = -(some constant)x, where x is the displacement from some equilibrium point. That's all that matters.
  • #35
Ah ok.
So final equation is t = 2π/(√4Gπρ/3)/m
Still not sure how I can simplify this but thanks.
  • #36
The mass should cancel and thus not appear in your final version.
  • #37
What I meant by saying the equation was wrong was in your #3 post you put the equation wrong. In actual fact the mass should come after the division. Thus
and not
which would make k = 4Gπρ and not k = 4Gπρm
Surely this means the m isn't canceled out at the end?
  • #38
and not
Those expressions are identical! (Except for the unneeded unit vector.) For the same reason that (a/b)x is the same as (ax/b).
  • #39
ah ok!
thats what confused me, i thought they were different. :-P
