Determine angle of twist in shaft
In summary, the torsional shear stress and angle of twist in degrees in an aluminum tube, 600 mm long, with an inside diameter of 60 mm and outside diameter of 80 mm, when subjected to a steady torque of 4500 N*m, is 0.012 rad. The correct formula for polar moment of inertia for a hollow shaft is J = pi (Do^4 - Di^4)/32. The wrong answer was obtained by using the wrong formula with Young's Modulus instead of the shear modulus for aluminum.
togo
106
Compute the torsional shear stress and angle of twist in degrees in an aluminum tube, 600 mm long, having an inside diameter of 60 mm and outside diameter of 80 mm when subjected to a steady torque of 4500 N*m. Then specify a suitable aluminum alloy for tube.
angle = TL/GJ
J = piD^4/32 (Do^4 - Di^4)
angle = (4500 N*m)(0.6 m) / (2.8 x 10^-6)(80 x 10^9) = 0.012 rad
Book answer: 0.0378 rad
Wrong answer obviously. Why? Thanks
This is wrong. Check formula for polar moment of inertia for hollow shaft.
my book doesn't have it
two examples for hollow shaft use the same J formula
The way you have it written, you have the units of length to the 8th power. That is not correct.
The correct formula is
Thanks for clearing that up
Re did calculation, same answer
Did you use Young's Modulus instead of the shear modulus for aluminum?
Yes I did. Thanks problem solved
Related to Determine angle of twist in shaft
What is the purpose of determining the angle of twist in a shaft?
The angle of twist in a shaft is an important measurement for ensuring the structural integrity and performance of mechanical systems. It helps engineers and designers determine the amount of torque and stress that a shaft can withstand without failing.
How is the angle of twist measured?
The angle of twist is typically measured using strain gauges attached to the surface of the shaft. These gauges detect the amount of deformation or strain in the material, which can then be used to calculate the angle of twist.
What factors can affect the angle of twist in a shaft?
The angle of twist in a shaft can be influenced by a number of factors, including the material properties of the shaft, the amount of torque or force applied, and the length and diameter of the shaft.
What is the formula for calculating the angle of twist?
The most commonly used formula for calculating the angle of twist in a shaft is the Torsion Formula, which is T = (Gθ)/L, where T is the applied torque, G is the shear modulus of the material, θ is the angle of twist, and L is the length of the shaft.
Why is it important to consider the angle of twist in shaft design?
Ignoring or underestimating the angle of twist in shaft design can lead to unexpected failures and malfunctions in mechanical systems. By accurately determining the angle of twist, engineers can design shafts that can withstand the required amount of torque and stress, ensuring the safety and reliability of the system.
  • Mechanical Engineering
