Determine Compositions of Functions
In summary, the conversation is about finding the values of various functions, including f(x), g(x), and h(x), and using them to determine the values of composite functions. The conversation also discusses the importance of understanding the concepts rather than just finding the answers.
Alaba27
This question is killing me. I'm finding it difficult to do and it's a problem with my homework.
Given that \(\displaystyle f(x)=2x^2-x+1,\,g(x)=2\sin(x)\text{ and }h(x)=3^x\), determine the following. You need not simplify the expressions.
\(\displaystyle f(g(-\pi))=?\)
\(\displaystyle \left(h^{-1}\circ f \right)(x)=?\)
\(\displaystyle g(f(h(x)))=?\)
I am so lost right now. Please help!
Mathematics news on Phys.org
Let's begin with the first one...what is \(\displaystyle g(-\pi)\)?
I thought it was (0,1), but I'm not sure.
You are only interested in the value the function returns not a point in the plane.
\(\displaystyle g(-\pi)=2\sin(-\pi)=-2\sin(\pi)\)
What is \(\displaystyle \sin(\pi)\) ?
That's 0.
Yes! (Cool)
So now, what is \(\displaystyle f(0)\) ?
MarkFL said:
Yes! (Cool)
1! So it is (0,1)?
It is just 1, when you write (0,1) this notation means an ordered pair, usually representing a point in a plane. I would write:
\(\displaystyle f(g(-\pi))=f(0)=1\)
Now for the second. We need to find \(\displaystyle h^{-1}(x)\). Do you know how to find the inverse of a function and how to check your work to make sure you did it correctly?
Alright. But I don't really understand how to do the second question. The thing is that I have to be done this question within the next 20 minutes because my tutor is only going to be available for a little bit today. :(
Well, we best get busy then...and I can't simply give you the answers because you have an impending deadline. My best advice is to ask for help earlier. I will be happy to stand in for your tutor to help you get these done, but I want to make sure you understand how to do them for yourself. Our goal is to make sure people gain a better understanding.
Do you know how to find the inverse of a function?
I know, and I'd rather understand how to do the work instead of just getting answers! I know how to find the inverses of functions, but I've never done it in a composition function.
We need not worry about the composition yet, all we need first is to find the definition of \(\displaystyle h^{-1}(x)\). Can you find this?
Once we have it, then we will proceed to find the given composition.
It's cube-root x.
That would be correct if \(\displaystyle h(x)=x^3\), but we have \(\displaystyle h(x)=3^x\). You are going to need to convert from exponential to logarithmic form.
https://www.physicsforums.com/attachments/846
Here are the answers:
$g(-\pi)=0$ so $f(g(-\pi))=1$. $h^{-1}(x)=log_{3}(x)$ so $h^{-1}(f(x))=log_{3}(2x^2-x+1)$. Finall, $f(h(x))=2.9^x-3^x+1$ so $g(f(h(x)))=2sin(2.9^x-3^x+1)$
FAQ: Determine Compositions of Functions
What is the definition of composition of functions?
Composition of functions is the process of combining two or more functions to create a new function. It involves using the output of one function as the input for another function.
How do you represent composition of functions?
The composition of two functions f and g is represented as (f ∘ g)(x), which is read as "f composed with g of x". It is also sometimes written as f(g(x)).
What is the domain and range of a composite function?
The domain of a composite function is the set of all values of x for which the composition is defined. The range is the set of all possible outputs of the composite function.
How do you evaluate a composite function?
To evaluate a composite function, you first evaluate the inner function using the given input. Then, you take the output of the inner function and use it as the input for the outer function. The resulting output is the value of the composite function.
What are some real-life applications of composition of functions?
Composition of functions is used in a variety of fields, including economics, computer science, and physics. It can be used to model complex systems, such as the stock market, and to create more efficient algorithms in programming. It is also used in physics to describe the relationship between different physical quantities.
