Determine eigenvalue-problem for steel pole
schniefen
Consider a steel pole of length ##L=1## m, which is not connected (free ends on both sides). For simplicity, we study only motions in the direction along the pole. Determine the eigenvalue-problem you need to solve.
The wave equation: ##\frac{\partial^2 \psi(x,t)}{\partial x^2}=\frac{\rho}{E}\frac{\partial^2 \psi(x,t)}{\partial t^2}##, where ##\rho## denotes density and ##E## pressure. Also, since the ends are free, ##\psi(0,t)=0## and ##\psi(L,t)=0##.
If we assume that ##\psi## has a Fourier transform ##\hat{\psi}##, so that ##\psi(x,t)=\frac{1}{2\pi}\int_{-\infty}^{\infty}\hat{\psi}(x,\omega)e^{i\omega t}\mathrm{d}\omega##, then the wave equation reduces to ##-\rho\omega^2\hat{\psi}(x,\omega)=E\frac{\partial^2 \hat{\psi}(x,\omega)}{\partial x^2}##, since the integrands need to equal. Also, we have ##\hat{\psi}(0,\omega)=0## and ##\hat{\psi}(L,\omega)=0##.
This already reveals the eigenvalue-problem, however, the answer given is ##-\lambda f(x)=\frac{\partial^2 f(x)}{\partial x^2}## with ##f(0)=f(L)=0##. How can ##\hat{\psi}(x,\omega)## be rewritten in terms of a function only depending on ##x## and why the partial derivatives notation if the function only does depend on a single variable?
Are those the right boundary conditions for free ends? Looks like fixed ends to me.
Likes vanhees71 and schniefen
You are right, I was wrong. The boundary conditions should read ##\frac{\partial \psi(x,t)}{\partial x}\bigg\rvert_{x=0}=0## and ##\frac{\partial \psi(x,t)}{\partial x}\bigg\rvert_{x=L}=0##. And these are the same for ##\hat{\psi}(x,\omega)##.
A follow-up to the question is to determine the vibrational frequencies. We have
##-\frac{\rho\omega^2}{E}\hat{\psi}(x,\omega)=\frac{\partial^2 \hat{\psi}(x,\omega)}{\partial x^2},##​
and define ##\lambda=\frac{\rho\omega^2}{E}##. Then ##\hat{\psi}(x,\omega)=\cos{(\sqrt{\lambda}x)}## satisfies the above equation as well as ##\frac{\partial \hat{\psi}(x,t)}{\partial x}\bigg\rvert_{x=0}=0##. The second boundary condition gives
##\frac{\partial \hat{\psi}(x,t)}{\partial x}\bigg\rvert_{x=L}=-\sqrt{\lambda}\sin{(\sqrt{\lambda}L)}=0.##​
This implies either ##\lambda=0## or
##\lambda_j=\left(\frac{(j+1)\pi}{L}\right)^2##
and thus
##\omega^2=\omega_j^2=\frac{E}{\rho}\left(\frac{(j+1)\pi}{L}\right)^2.##​
The frequencies are then simply ##f_j=\frac{\omega_j}{2\pi}=\sqrt{\frac{E}{\rho}}\frac{j+1}{2L}##. I am a little uncertain about the range of ##j## though. There should be a frequency that is ##0##, which would imply ##j=-1,0,1,2, ...##.
schniefen said:
This implies either λ=0 or
Why break it into two cases? Doesn't ##\lambda_j=(\frac{j\pi}L)^2##, ##j=0, 1, 2,..## cover it?
