Determine half life from gamma radiation
In summary, the author is working on a lab and trying to determine the half life of an element. He has all the data, but cannot relate the gamma radiation to the half life. He needs help and asks for advice.
alivedude
58
I'm working on a lab and the task is to determine the half life of an element studying the beta radiation or the gamma radiation (emitted from the daughter). I have all the data and I'm done with the beta part, that was pretty straight forward. I have no clue how to relate the gamma radiation to the half life. This is how far I have come:
When a nucleus decays (in this case beta) it often leaves the daughter in an excited state. The daughter lowers it's energy by emitting photons but this doesn't necessary happens instant, right? So I can't count the photons and use the same equation as for beta radiation?
I don't even understand how I can relate the radiation from the daughter to the half life of the parent? I just need a push in the right direction.
Cheers! :)
Depends on the isotope. As an example, if your beta decay has a half-life of 1 year, and the gamma decay has a half-life of one nanosecond, you can assume it to be instantly. Most gamma transitions happen even faster, just a few metastable nuclei have relevant lifetimes.
In general, the distribution of the gamma radiation will depend on both lifetimes (or even more if you have more than one gamma transition). If you know the distribution well enough, you can measure both at the same time. In practice, that will rarely work, so you need some approximation or other external input.
Hmm okay, thanks!
I think I need to ask my assistant about this because it sounds a bit beyond our scope in this course. Because I know there is several gamma transitions in my isotopes and I'm studying two isotopes at the same time, how should I know which photons that comes from what nucleus? Can I measure their energy and go from that in somehow?
If you have a detector that can measure the energy: sure. Those transitions usually have well-defined energies (if they don't, then they are really shortliving), and you can look them up.
Yeah we have such a detector in the lab and I found decay schemes so I know their transitions energies. But I still don't understand how you can relate these energies to the half-lifes?
Well, with the energy you can figure out which isotope lead to the decay, and then you can study how the rate changes over time (if the lifetime is short enough) or find a relation between total activity and sample size (if the lifetime is too long to observe the reducing decay rate over time).
It was actually much easier than I thought. After some checking the decays schemes I noticed that it was only one photon per isotope and it was emitted in nano seconds, so I could only count the photons basically. I just overcomplicated it all :) Thanks anyway for the help!
Related to Determine half life from gamma radiation
1. What is gamma radiation?
Gamma radiation is a type of high-energy electromagnetic radiation that is produced during radioactive decay. It has the shortest wavelength and highest frequency among all types of radiation.
2. How is half life determined from gamma radiation?
The half life of a radioactive substance can be determined by measuring the rate at which gamma radiation is emitted from the substance over time. As the substance decays, the amount of gamma radiation emitted decreases, allowing scientists to calculate the half life.
3. What is the significance of determining half life from gamma radiation?
Determining the half life of a radioactive substance is important for understanding its decay rate and potential hazards. It also allows scientists to accurately predict how long it will take for the substance to decay to a safe level.
4. Can half life be calculated for all types of radioactive substances?
Yes, the concept of half life can be applied to all types of radioactive substances, including those that emit gamma radiation. However, the specific method for determining the half life may vary depending on the type of radiation being emitted.
5. What are some common uses for determining half life from gamma radiation?
Determining the half life of a substance can be useful in a variety of fields, including nuclear medicine, environmental science, and archaeology. It can also be used to monitor and regulate exposure to radiation in industries such as nuclear power and medical imaging.
