Determine if the improper integral is divergent or not
In summary, an improper integral is an integral with either infinite limits or a vertical asymptote within the interval of integration. To determine its convergence or divergence, techniques such as the limit comparison test, direct comparison test, or integral test can be used. The limit comparison test involves comparing the integral to a simpler integral with known convergence or divergence. The direct comparison test involves comparing the integral to another integral with similar integrands. The integral test involves comparing the integral to a corresponding infinite series.
Fatima Hasan
319
Determine if the improper integral is divergent or convergent .
When i solved the first term using online calculator , the answer was "The integral is divergent" . However , I got 0 .
Where is my mistake ?
You cannot generally do things like ##\infty - \infty = 0##. Furthermore, what you have is not ##\infty - \infty## as ##1/[2(0^2 - 1)] = -1/2##.
It should be ##-1/[2(1^2-1)] +- 1/[2(0^2-1)]= -1/0 + 1/2 = -\infty+1/2##
So , it's divergent . Right ?
FAQ: Determine if the improper integral is divergent or not
What is an improper integral?
An improper integral is an integral where either the limits of integration are infinite or the integrand has a vertical asymptote within the interval of integration.
How do you determine if an improper integral is convergent or divergent?
To determine if an improper integral is convergent or divergent, you must evaluate the integral using appropriate techniques such as the limit comparison test, direct comparison test, or the integral test.
What is the limit comparison test?
The limit comparison test is a method for determining the convergence or divergence of an improper integral by comparing it to a simpler integral with known convergence or divergence.
What is the direct comparison test?
The direct comparison test is a method for determining the convergence or divergence of an improper integral by comparing it to another integral with known convergence or divergence, where the integrands are similar in form.
What is the integral test?
The integral test is a method for determining the convergence or divergence of an improper integral by comparing it to a corresponding infinite series. If the series converges, then the integral also converges, and vice versa.
