lmae
- 8
Showing full working determine if x = -2 is a solution to the equation 2x – 2 = 3x
lmae said:Showing full working determine if x = -2 is a solution to the equation 2x – 2 = 3x
To determine if x = -2 is a solution to the equation 2x – 2 = 3x, we substitute x = -2 into the equation and solve for both sides. If the equation holds true, then x = -2 is a solution.
Finding solutions to equations is important in science because it allows us to make predictions and understand the relationships between variables in a system. It also helps us to test and validate theories and models.
Yes, there can be more than one solution to an equation in science. This is especially true in systems with multiple variables and complex relationships between them. It is important to carefully analyze and interpret the solutions to determine their significance.
A solution to an equation is considered valid in science if it satisfies all of the conditions and constraints of the system being studied. This can include physical laws, mathematical relationships, and experimental data.
Yes, equations can be used to make predictions in science. By solving equations and finding solutions, we can make predictions about the behavior of a system under different conditions and test these predictions through experimentation.
