physicsphreak2
- 13
From Zangwill, Chapter 2.
Suppose that the instantaneous forces on a charge, [itex]q[/itex], when it is moving with velocities [itex]\vec{v}_1[/itex] or [itex]\vec{v}_2[/itex], are [itex]\vec{F}_1[/itex] and [itex]\vec{F}_2[/itex], respectively. Without choosing a coordinate system, show that [itex]\vec{B}(\vec{r}) [/itex] can be determined by working with the observable quantities [itex]\vec{v}_1 \times \vec{F}_1 [/itex] and [itex]\vec{v}_2 \times \vec{F}_2 [/itex], with [itex] \vec{v}_1 [/itex] and [itex] \vec{v}_2 [/itex] being suitably chosen.
Lorentz force law: [itex] \vec{F} = q(\vec{v} \times \vec{B}(\vec{r})) [/itex]
I recognize that [itex] \vec{v}_i \times \vec{F}_i = \vec{v}_i (\vec{v}_i \cdot \vec{B}(\vec{r})) - \vec{B}(\vec{r})(|\vec{v}_i|^2)[/itex] by the BAC-CAB rule, with i=1 or 2 in this case.
So, I am tempted to say that if you judiciously choose the direction such that [itex] \vec{v}_i \perp \vec{B}(\vec{r}) [/itex] we can immediately get the magnetic field (because the first term in the BAC-CAB expansion is zero, if the vectors are perpendicular). I might argue that we can do this by considering all possible velocities until we have maximized the force (since that max comes when the vectors being crossed are perpendicular)... would that be a satisfactory way to find those special directions for the velocities?
But would I also need the test velocities [itex] \vec{v}_i [/itex] to be perpendicular to each other? Otherwise, they could be anywhere in the plane perpendicular to [itex] \vec{B} [/itex]. And, once I have required this, I have the vector components of [itex] \vec{B} [/itex] in 2 directions (the directions determined by [itex] \vec{v}_i \times \vec{F}_i [/itex]). Actually, maybe I only have it in one direction since the velocity vectors form a plane, so their cross products with each force will be parallel??
How do I determine the magnitude of [itex] \vec{B} [/itex] in the 3rd direction, the one perpendicular to the plane spanned by the two velocity vectors I have chosen? I feel like I only have 2 of the three components of the the magnetic field using my method.
Am I at least close?!
