Determine Planck's Constant from gradient
In summary, Planck's constant (h) is a fundamental constant in physics that relates the energy of a photon to its frequency. It can be determined from the gradient of a graph that plots photon energy against frequency, with the gradient being equal to h divided by the charge of an electron. Determining Planck's constant is significant as it helps us understand the behavior of light and other electromagnetic radiation at a quantum level, and has practical applications in fields such as electronics and telecommunications. The unit of measurement for Planck's constant is joule-second (J·s) in the International System of Units (SI). It was first calculated by Max Planck in 1900 using experimental data on blackbody radiation.
ZedCar
354
I have a graph entitled "Photoelectric effect: stopping voltage as a function of light frequency"
The y-axis is the Stopping Voltage (V), the x-axis the Frequency (Hz).
How do I determine Planck's Constant (h) from the gradient?
Thanks!
What is the kinetic energy of a photo-emitted electron?
ZedCar said:
Why is your "Relevant equations" section blank? It is a photoelectric effect problem, look up the equation that describes the photoelectric effect.
FAQ: Determine Planck's Constant from gradient
1. What is Planck's constant?
Planck's constant, denoted by the symbol h, is a fundamental constant in physics that relates the energy of a photon to its frequency.
2. How can Planck's constant be determined from gradient?
Planck's constant can be determined from the gradient of a graph that plots the energy of a photon against its frequency. The gradient is equal to h divided by the charge of an electron.
3. What is the significance of determining Planck's constant?
Determining Planck's constant is significant because it allows us to understand the behavior of light and other electromagnetic radiation at a quantum level. It also has practical applications in fields such as electronics and telecommunications.
4. What is the unit of measurement for Planck's constant?
Planck's constant has a unit of joule-second (J·s) in the International System of Units (SI).
5. How was Planck's constant first calculated?
Planck's constant was first calculated by German physicist Max Planck in 1900 using experimental data on the radiation emitted by hot objects, known as blackbody radiation. He derived a mathematical formula that related the energy of a photon to its frequency, which included the constant h.
