Determine the capacitor value so that this circuit is in resonance
In summary: Adding these two vectors gives you the resulting impedance Z.In summary, the conversation discusses using the values of L, ω, and R2 to calculate the parallel impedance Z parallel, as well as the use of complex numbers to represent impedances. The final step involves combining the impedance Z with the impedance Z parallel to get the total impedance, taking into account the phase angles.
baywa2
Need to determine capacitor value so that the circuit is in resonance
E=21∠0º
ω=10^3 rad/s
R1=10Ω
R2=40Ω
L=100mh
C=?
246672
L=100mh=0.1H
ω=10^3 rad/s -> f = 159Hz
XL= ωL= 2πfL= 2π*159*0.1= 99.90 Ω
Z parallel = [(XL∠90º)*R2] / [(XL∠90º)-R2]= 37.13∠-21.8º
XC= 1/ωC= 1/(2 π f C)
I don't see how I am supposed to get to C
baywa2 said:
L=100mh=0.1H
OK. Here, it is easier to use XL = ωL rather than XL = 2πfL. Your value of 99.90 has a bit of round off error.
Check the sign of R2 in the denominator.
Are you familiar with using complex numbers to represent impedances? For me, that makes things easier.
Think about how to combine the resistance R1 and the reactance of C with the result for Z_parallel. Can you see that C, R1, and Z_parallel are all in series?
Likes baywa2
Ok
so Z parallel = [(XL∠90º)*R2] / [(XL∠90º)+R2]
I get Z is some 37 Ω
So do I then use R1 and C for Z? Z=R1+XC∠-90º
Then add the Z and Zpar? 10+37+XC∠-90º -> 47+XC∠-90º
baywa2 said:
Ok
There should also be a phase angle for the 37 Ω.
You can't combine the 10 and the 37 to get 47 since the 37 has a nonzero phase angle. It's like adding vectors. The 10 Ω corresponds to a vector pointing along the x-axis since it has zero phase angle. The 37 Ω corresponds to a vector pointing at some angle above the x axis.
Related to Determine the capacitor value so that this circuit is in resonance
1. How do you calculate the capacitor value for resonance?
The capacitor value for resonance can be calculated using the formula C=1/((2*pi*f)^2*L), where C is the capacitance in farads, f is the frequency in hertz, and L is the inductance in henries.
2. What is the importance of resonance in this circuit?
Resonance is important in this circuit because it allows for maximum energy transfer between the capacitor and inductor, resulting in a higher voltage and stronger oscillations.
3. Can the capacitor value be adjusted to change the resonance frequency?
Yes, the capacitor value can be adjusted to change the resonance frequency. As the capacitance increases, the resonance frequency decreases and vice versa.
4. How does the resistor affect the capacitor value for resonance?
The resistor does not directly affect the capacitor value for resonance, but it does play a role in determining the overall impedance of the circuit and the amount of energy lost due to resistance.
5. What happens if the capacitor value is too high or too low for resonance?
If the capacitor value is too high or too low for resonance, the circuit will not be able to reach its maximum energy transfer and the oscillations will be weaker. This can also result in a shift in the resonance frequency.
