Determine the depth of a swimming pool filled with water
In summary, we wished to determine the depth of a swimming pool filled with water without getting wet. We measured the width of the pool, which is 5.50m. We then noted that the bottom edge is just visible when we stand and look at an angle of 14.0 degrees above the horizontal line. We calculated the depth of the pool to be 5.15m.
Sammiebaby966
We wish to determine the depth of a swimming pool filled with water without getting wet. We measure the width of the pool, which is 5.50m. We then note that the bottom edge is just visible when we stand and look at an angle of 14.0 degrees above the horizontal line.
a)Calculate the depth of the pool.
b)If the pool were filled with a different clear liquid, with index of refraction n=1.65. Would you be able to see the bottom of the pool from the side now?
c)The bottom of the pool is made of a clear solid material. What would be the maximum value of index of refraction of thisclear floor so that total internal reflection occurs? (It is filled with the n=1.65 liquid).
Hi Sammiebaby, welcome to PF.
Please go through the rules of PF.
You have to your attempts before you seek our help.
At least find out the relevant equation required to solve the given problem.
Can you draw the ray diagram? can you state the Snell's law? What is the critical angle?
Sin[tex]\theta[/tex]1n1=Sin[tex]\theta[/tex]2n2
I got the angle of the index of refraction.
Sin[tex]\theta[/tex]2=(1.00/1.33)Sin(14')=.182
[tex]\theta[/tex]2=Sin^-1(.182)
[tex]\theta[/tex]2=10.5'
Im not sure how to find the depth tho.
The given angle is above the horizon. So it is not the angle of incidence.
Draw the ray diagram and identify the different angles.
Find the angle of refraction. If you see the diagram, you can see that tanθ2 = width/depth.
So,
tan(10.5')=5.50m/x
x=5.50m/tan(10.5')
x=29.7m
So the depth is 29.7m? I am confused because that seems large.
Sammiebaby966 said:
So,
tan(10.5')=5.50m/x
x=5.50m/tan(10.5')
x=29.7m
Your angle of refraction is wrong. The angle of incidence is (90 - 14) degrees.
Oh wow, I am having a slow night sorry!
Sooo let's try this again:
Sin[tex]\theta[/tex]2=(1.00/1.33)Sin(76)=.730
[tex]\theta[/tex]2=Sin^-1(.730)
[tex]\theta[/tex]2=46.9'
Sooo,
tan(46.9')=(5.50m)/depth
Depth=(5.50m)/tan(46.9')
Depth=5.15m
That sounds better. Did I mess up again or did I get it right?
Yes. You are right.
Thank you so much! =]
Related to Determine the depth of a swimming pool filled with water
1. How do you determine the depth of a swimming pool filled with water?
To determine the depth of a swimming pool filled with water, you will need a measuring tape or a yardstick. First, make sure the pool is completely filled with water. Then, carefully lower the measuring tape or yardstick into the water until it reaches the bottom of the pool. The measurement at the water level will be the depth of the pool.
2. What is the best way to measure the depth of a swimming pool?
The best way to measure the depth of a swimming pool is by using a measuring tape or a yardstick. These tools are long enough to reach the bottom of the pool and provide an accurate measurement. Avoid using a ruler or any other short tool that may not reach all the way to the bottom of the pool.
3. Is it important to know the depth of a swimming pool?
Yes, it is important to know the depth of a swimming pool for safety reasons. The depth of the pool determines how deep the water is, and therefore, how safe it is for diving or other activities. It is also important for maintaining the proper chemical balance in the pool, as different depths may require different amounts of chemicals.
4. How often should the depth of a swimming pool be measured?
The depth of a swimming pool should be measured at least once a year, preferably before the start of swimming season. This will ensure that the pool is at the correct depth and that the water level is not too high or too low. If the pool is used frequently, it is recommended to measure the depth more often to ensure the safety of swimmers.
5. Can the depth of a swimming pool change over time?
Yes, the depth of a swimming pool can change over time due to various factors such as evaporation, splash-out, and water usage. It is important to regularly measure the depth of a pool and make adjustments to the water level if needed. Additionally, weather conditions, such as heavy rain, can also affect the depth of a swimming pool.
  • Classical Physics
  • Mechanical Engineering
  • Earth Sciences
16K
