MHB Determine the diameter of the graph
  • Thread starter Thread starter mathmari
    Diameter Graph
The discussion focuses on determining the diameter of a graph represented by a specific adjacency matrix. Participants clarify that the graph's diameter is defined as the maximum distance between any two vertices, measured in edges, rather than vertices. It is established that the graph has eight vertices arranged in a circular manner, and the maximum distance between two vertices is determined to be four edges. The conversation emphasizes that calculating eigenvalues is not necessary for finding the diameter. The final consensus confirms that the diameter of the graph is indeed four.
mathmari
MHB
Hey! :o
We have the matrix $$A=\begin{pmatrix}0&1&0&0&0&0&0&1\\1&0&1&0&0&0&0&0\\0&1&0&1&0&0&0&0\\0&0&1&0&1&0&0&0\\0&0&0&1&0&1&0&0\\0&0&0&0&1&0&1&0\\0&0&0&0&0&1&0&1\\1&0&0&0&0&0&1&0\end{pmatrix}$$
and we want to determine the diameter of the graph.
For that do we have to calculate the eigenvalues? Or isn't the diameter related to the number of eigenvalues? (Wondering)
mathmari said:
Hey! :o
Hey mathmari!
I'm not aware (yet) of a relationship between eigenvalues and diameter.
But to find the diameter, we can draw the graph, and figure out its diameter from the graph can't we? (Wondering)
Do we have the following graph?
(Wondering)
Yep. (Nod)
I like Serena said:
Yep. (Nod)
Graph's diameter is the largest number of vertices which must be traversed in order to travel from one vertex to another, right? Is the largest number of vertices equal to 8? (Wondering)
Not vertices but edges.
It's the largest possible 'distance' between 2 vertices. (Nerd)
I don't think so.
We have 8 vertices in total that are effectively arranged in a circle.
If we pick 2 of them, what is the distance (the minimum number of edges) between them? (Wondering)
The minimum numbers of edges between two vertices is 2, right? Is this the diameter? (Wondering)
Nope.
The distance between 2 vertices is the minimum number of edges between those vertices.
And the diameter is the maximum distance that we can find.
If we pick 2 neighboring edges (one edge between them), the distance is 1.
But we can also pick vertices that are further apart can't we? (Thinking)
I like Serena said:
Nope.
The maximum distance between two vertices is 4, or not? (Wondering)
Yes it is. (Nod)
I like Serena said:
Yes it is. (Nod)
Ok! Thank you! (Smile)
