Determine the energies of the three lowest energy states.
In summary, the conversation discussed determining the energies of the three lowest energy states for a particle confined to a two-dimensional box with specific boundary conditions. The homework equations and attempt at a solution were also mentioned, with the correction that the wave function provided was for the first excited state, not the ground state. It was also noted that there is a difference between boxes with different boundary conditions.
qweazy
A particle is confined to a two-dimensional box defined by the following boundary conditions: U(x, y) = 0 for [itex]\frac{-L}{2}[/itex] ≤ x ≤ [itex]\frac{L}{2}[/itex] and
[itex]\frac{-3L}{2}[/itex] ≤ y ≤ [itex]\frac{3L}{2}[/itex], and U(x, y) = ∞ outside these ranges. Determine the energies of the three lowest energy states
Just want the setup right
ψ(x,y,z)=Asin(k[itex]_{1}[/itex]x)sin(k[itex]_{2}[/itex]y)sin(k[itex]_{3}[/itex]z)
So I first started off with
ψ(x,y)=0 at x=[itex]\frac{L}{2}[/itex] and y=[itex]\frac{3L}{2}[/itex]
[itex]\Rightarrow[/itex] k[itex]_{1}[/itex]=[itex]\frac{2n_{1}π}{L}[/itex] and k[itex]_{2}[/itex]=[itex]\frac{2n_{2}π}{3L}[/itex]
So then the energy =
[itex]\frac{h^{2}}{8π^{2}m}[/itex](k[itex]^{2}_{1}[/itex]+k[itex]^{2}_{2}[/itex])
=[itex]\frac{h^{2}}{8π^{2}m}[/itex]([itex]\frac{4n^{2}_{1}π^{2}}{L^{2}}[/itex]+[itex]\frac{4n^{2}_{2}π^{2}}{9L^{2}}[/itex])
π[itex]^{2}[/itex] cancels out, factor out 4 and L[itex]^{2}[/itex]
[itex]\frac{h^{2}}{2mL^{2}}[/itex](n[itex]^{2}_{1}[/itex]+[itex]\frac{n^{2}_{2}}{9}[/itex])
I have it wrong, but I don't know why
the actual one is
[itex]\frac{h^{2}}{8mL^{2}}[/itex](n[itex]^{2}_{1}[/itex]+[itex]\frac{n^{2}_{2}}{9}[/itex])
You are not calculating the ground state energy! Your wave function is for the first excited state!
Note that there is a difference between boxes [0,L] and [-L/2, L/2]. In the former, the solution is A sin(kx), as B cos(kx) can't satisfy the boundary conditions (0 when x=0). In the latter case however, both solutions must be considered, and in fact, the ground state is the first cosine state.
Oh ok I see. I just thought that Asin(kx) applied for everything. It makes sense now, thanks for your help!
Related to Determine the energies of the three lowest energy states.
1. What are energy states?
Energy states refer to the quantized energy levels that an atom or molecule can have. These levels are determined by the arrangement and movement of electrons within the system.
2. Why is it important to determine the energies of the lowest energy states?
Determining the energies of the lowest energy states is important because it provides valuable information about the stability and behavior of the system. These states are typically the most common and can be used to predict the behavior of the system under certain conditions.
3. How are the energies of the lowest energy states determined?
The energies of the lowest energy states are determined through various experimental techniques, such as spectroscopy, or through theoretical calculations, such as using quantum mechanics equations. These methods allow scientists to measure or predict the energy levels of the system.
4. Can the energies of the lowest energy states change?
Yes, the energies of the lowest energy states can change under certain conditions. For example, if the system is exposed to external energy sources, such as heat or light, the energy levels can shift. Additionally, the arrangement of electrons within the system can also affect the energies of the lowest energy states.
5. How do the energies of the lowest energy states affect chemical reactions?
The energies of the lowest energy states play a crucial role in chemical reactions. The reactants must have enough energy to overcome the energy barrier between them and the product, which is determined by the energy levels of the system. The lower the energy states, the easier it is for the reactants to form products, making the reaction more favorable.
