Determine the energy of an alpha particle
In summary, Ek=4.78 MeV, m=1.52x10^7 kg, V=5% the speed of light, p=0.09 MeV, α=4.78 MeV, and Rn=0.09 MeV.
sciencegeek101
I have been asked to determine the energy in MeV of an alpha particle and an Rn nucleus in the decay of Ra-226 using the conservation of energy and momentum. (assume Ra is at rest)
Here is what i have done, I am just wondering if i did it properly. Thanks for your help :)
Ek=kinetic energy
m=mass
V=velocity
p=momentum
α=alpha particle
Rn= radon nucleus
Q= Energy
226Ra→222Rn + 4He + Q
88 86 2
Ekα= 1/2mV^2
= 1/2 (4.002606amu/6.02x10^26kg/amu) (1.52x10^7m/s)^2
= 7.67x10^-13J x 1MeV/1.6022x10^-13J
= 4.78 MeV for the kinetic energy of the alpha particle
(I read that the velocity of an alpha particle is 5% the speed of light, so that's where I got 1.52x10^7 but this could be wrong)
Next since momentum is conserved
mα(Vα)=mRn(VRn)
Vα/VRn=mRn/mα
4.78MeV/VRn=222.017578amu/4.002603amu
VRn= 0.09MeV
So the speeds in MeV are α= 4.78MeV and Rn=0.09MeV
Did I miss any steps or make any mistakes?
There is no fixed speed. If they have more energy they are faster, if they have less energy they are slower.
To solve this problem you'll need some information about the decay, like the decay energy.
A speed in MeV does not make sense. What is your height in Volts?
Here is the exact question
using conservation of momentum and energy, determine the energies in MeV of the alpha particle and the Rn nucleus in the decay Ra-226. You may assume that the Ra nucleus is initially at rest.
I don't understand what this "+Q" in your question refers to. If this is a usual ##\alpha## decay, you just need to do the usual decay kinematics of a two-body decay. Usually one works in the reference frame, where the decay particle is at rest. Then you have (in natural units with ##\hbar=c=1##)
$$p=(M,0,0,0)$$
for the radium nucleus in the initial state, and energy-momentum conservation tells you that
$$p=q_1+q_2,$$
where ##q_1## and ##q_2## are the four-momenta of the ##\alpha particle## and the Radon nucleus. Additionally you have the on-shell conditions ##q_1^2=m_{\alpha}^2## and ##q_2^2=m_{\text{Rn}}^2##.
Now to get the momentum ##\vec{q}_1=-\vec{q}_2## of the ##\alpha## particle just take the square of the energy-momentum conservation equation (in the sense of the Minkowski product)!
$$p=(M,0,0,0)$$
$$p=q_1+q_2,$$
Q represents the total energy released in the process of radium decay. I found this value to be 4.87 MeV in my textbook
I see, but that's implied in my formalism too. It's implied by the masses of the involved particles. So let's see, whether I can reproduce your results. The simplest way is to use the energy-momentum conservation equation in the form
$$q_2=p-q_1 \; \Rightarrow \; q_2^2=m_{\text{Rn}}^2=p^2+q_1^2-2 p \cdot q_1=m_{\text{Ra}}^2+m_{\alpha}^2-2 m_{\text{Ra}} E_{\alpha}$$
Solving for ##E_{\alpha}## gives
$$E_{\alpha}=\frac{m_{\text{Ra}}^2+m_{\alpha}^2-m_{\text{Rn}}^2}{2m_{\text{Ra}}}=3733 \;\text{MeV}$$
From this you get
$$q_1=p_{\alpha}=\sqrt{E_{\alpha}^2-m_{\alpha}^2}=189 \;\text{MeV}.$$
The speed of the ##\alpha## particle thus is
$$v=\frac{p_{\alpha}}{E_{\alpha}}=0.051,$$
i.e., it goes with 5.1% of the speed of light. So that's correct.
Likes sciencegeek101
I moved the thread to our homework section.
@vanhees71: Your numbers are inconsistent, see WolframAlpha.
Good, that is the sum of the kinetic energies of the two nuclei. You can use this plus momentum conservation to get the energies and speeds of both products. Newtonian mechanics should be fine as approximation.
Hm, I took the masses of the particles from some online nuclide data base. I attatch the pdf of the Mathematica Notebook used to do the calculation.
  • radon-decay-kinematics.pdf
Ah, your energy includes the rest energy of the alpha particle. I think the problem asks for the kinetic energy.
Anyway, we shouldn't do OPs homework.
Of course, I was too lazy to think about the non-relativistic approximation. For the kinetic energy you get ##E_{\text{kin},\alpha}=E_{\alpha}-m_{\alpha}=4.79 \, \text{MeV}##.
Related to Determine the energy of an alpha particle
1. What is an alpha particle?
An alpha particle is a type of ionizing radiation that consists of two protons and two neutrons. It is the largest and most massive type of radiation and is emitted by radioactive materials.
2. How is the energy of an alpha particle determined?
The energy of an alpha particle can be determined using the equation E = mc², where E is the energy, m is the mass of the alpha particle, and c is the speed of light.
3. What is the unit of measurement for alpha particle energy?
The unit of measurement for alpha particle energy is electron volts (eV) or megaelectron volts (MeV). This unit is used to measure the amount of energy gained or lost by an alpha particle during a nuclear reaction.
4. What factors can affect the energy of an alpha particle?
The energy of an alpha particle can be affected by the type of radioactive material it is emitted from, the distance it travels, and any barriers it encounters. Additionally, the energy of an alpha particle can be altered by electric and magnetic fields.
5. Why is it important to determine the energy of an alpha particle?
Determining the energy of an alpha particle is important for understanding the properties and behavior of radioactive materials. It can also be used in various applications such as medical imaging and cancer treatment, as well as in the development of nuclear energy technologies.
13K
