Determine the equation for the the tangent
  • Thread starter Gliese123
  • Tags
    Tangent
In summary, the student is trying to find the equation for the tangent-to-the-curve, but doesn't understand how to take the derivative and plug it in.
Gliese123
144
Determine the equation for the the tangent-to the curve:
y=3 sin 2x - cos 2x
if x=3∏/4
So I thought I might get the y?
y=3 sin 2(3∏/4) - cos 2(3∏/4)
y= ~0.25 - ~1 ≈ 0.75
k(?) =
m(?) =
Then what?
Please help :(
The answer is y = -2x + 3∏/2 - 3
For y=3 sin2x - cos2x, how would you find the gradient function i.e. the function which gives the gradient at any point x?
y=3 sin 2x - cos 2x
if x=3π/4
y=3 sin 2(3π/4) - cos 2(3π/4)
This isn't correct. If you are using a calculator, are you sure you are in radian mode?
Once you get the correct y coordinate in the point, find the derivative of y. Plug x = 3π/4 into the derivative to get the slope of the tangent line. Finally, plug in the point and slope into the point-slope form of the equation of a line.
I don't know really. Should I deriving?
No I think its adjustments are set to angles. Is it possible to do it without setting it to radians?
Do you know the definition of the derivative in terms of the tangent line?
This is what I think roc.freak was getting at.
You could also memorize the sine and cosine of special angles.
[itex]y = 3 \sin \left(2 \cdot \frac{3\pi}{4}\right) - \cos \left(2 \cdot \frac{3\pi}{4}\right)[/itex]
[itex]y = 3 \sin \left(\frac{3\pi}{2}\right) - \cos \left(\frac{3\pi}{2}\right)[/itex]
3π/2 is one such special angle. What is
[itex]\sin \left(\frac{3\pi}{2}\right)[/itex]
and
[itex]\cos \left(\frac{3\pi}{2}\right)[/itex]?
and
When I put that on the calculator I get:
sin to be -0.99... and cos to be -2.38 × 10-3 :cry:
And it's set to radians.
Should I take 3 × -0.9999 = -3. Is that the gradient?
No. Sorry. I know how to derivate sin, cos etc. though :redface:
Something is wrong with your calculator. Because
sin (3π/2) = -1 and cos (3π/2) = 0.
No, it's not the gradient! It's the y-coordinate of the point where the tangent line intersects the curve. Please reread my post.
Oh sorry!:redface: Hm. Okay so is y= -1 then? Sigh.. I don't know?
Should I derivate the function and put -1 = (the derivation)? (And include x)?
Gliese123 said:
Oh sorry! Hm. Okay so is y= -1 then? Sigh.. I don't know?
No, y does not equal -1. There was a 3 in front of the sine.
No again. You should take the derivative of
[itex]y = 3 \sin 2x - \cos 2x[/itex]
[itex]y' = ...[/itex]
and then plug in x = 3π/4. y' is the slope of the tangent line at x = 3π/4.
So
y' = 3cos2x + 2sin2x right?
y' = 3 cos 2(3∏/4) + 2 sin 2(3∏/4) = - 4 ?
Could you lead me through please? I can't do this on my own. :confused:
Gliese123 said:
So
No. You are forgetting the chain rule.
I give up... Thanks very much for the help though.. :)
The problem appears to be that you are trying to do a Calculus problem involving trig functions but have never learned Calculus or Trigonometry.
It's in "homework" ... so it looks like OP is doing a course that requires calculus and trigonometry without having learned the prerequisites.
Actually, the question would be a good entry test for any situation where a basic understanding of calc and trig are required but not taught. Like a job interview.
Yes. It's in "Homework" which means that I'm no pro on this one. I just started with the concept of derivations in trigonometry. I get that there're a lot of rules when one derivate functions including trigonometry. What have caused me to fail the calulations is because my calculator seem to not be set to the primary settings. I hoped that someone could more or less tell me the finnish. That would be helpful, not just telling me what's wrong all the time. :smile:
You mean, "derivatives of trigonometric functions"?
Or, that your course is on the concepts of differentiating trigonometric functions?
"when one differentiates functions"
You don't need a calculator at all so this is not true.
That would be against the forum rules.
The idea is that you do your homework - we can help out where you get stuck but we will not do the work for you. Thing is, you have been stuck on everything. You do not know how a sine function varies with angle, and you don't know the chain rule. Both of these things were in an earlier part of your coursework.
Therefor: you have to go back over your course notes.
Well, don't get me wrong now, but why did I even bother to write the question here? Math isn't easy to understand, that's for sure but wow, this takes the prize of impossibility. I respect the forum rules but I guess that I need to be 99% knowing of the statement's problem to even write it here. I'll have that in mind. Thank you..
Okay dudes I got the answer:
y= 3sin 2x - cos 2x (x=3∏/4) =>
y= 3 sin 2(3∏/4) - cos 2(3∏/4)
y=-3
y' = 6cos2x - 2sin 2x
y' = 6cos2(3∏/4) - 2sin 2(3∏/4)
y'= -2 (-2= gradient I guess??)
y= kx + m
-3= -2(3∏/4) + m
m = -2(3∏/4) -3 m = 3∏/2 - 3 short
So:
y = -2x + (3∏/2) - 3
It looks right at least?
derivative of cosine is -sine
you can figure it out from a sketch of the cosine curve and looking at the gradient at different places. The cosine starts out at y=1 with gradient of 0 ... as x increases, the gradient becomes negative. When the cosine first crosses the axis, the gradient is -1/2. And so on. You don't need to memorize this if you know what a gradient is and you can sketch, even very roughly, the cosine function.
If you don't take the trouble to understand things you will keep repeating the same mistakes.
Turn that around - why do we even bother trying to help you?
When someone does not want to learn, does not come with even the basic concepts around the subject so we basically have to teach them maths - for free? This is a two-way street. You've posted enough here to know the score by now.
Actually, if the place you get stuck is understanding the problem, then we can and will unstick you. That is not the same a doing the problem for you.
The principle is that you learn best by doing the work yourself. I know it is hard. We all do. We all did it the same way, tried shortcuts and walkthrough's, learned the hard way that this is a mistake, and now pass this on for the next generation to ignore ;)
There are services which provide the kind of assistance you asked for ... but you usually have to pay for them.
One of the neat things about offering free help is that you get to offer the help that people need rather than the help that they ask for. When you pay for my help, then you get to tell me what to do.
You don't have to take the advise offered here. You don't even have to like it.
Yeah. Well. I thank you for your effort :) Don't misstaken me :) What I got seemed to be right. That what's matters :)
FAQ: Determine the equation for the the tangent
What is the equation for the tangent line?
The equation for the tangent line is y = mx + b, where m is the slope of the tangent line and b is the y-intercept.
How do you determine the slope of a tangent line?
To determine the slope of a tangent line, we use the derivative of the function at the point of tangency. This derivative represents the rate of change of the function at that specific point, which is equivalent to the slope of the tangent line.
Can the equation for the tangent line be negative?
Yes, the slope of the tangent line can be negative if the function is decreasing at the point of tangency. This indicates that the tangent line is sloping downwards from left to right.
How does the equation for the tangent line relate to the original function?
The equation for the tangent line is a linear approximation of the original function at a specific point. It represents the instantaneous rate of change of the function at that point and can be used to estimate the value of the function nearby.
Can the equation for the tangent line be used to find the maximum or minimum of a function?
Yes, the equation for the tangent line can be used to find the maximum or minimum of a function. This is because the tangent line is horizontal at the point of maximum or minimum, meaning the slope (derivative) is equal to zero. By setting the derivative equal to zero, we can solve for the x-value of the maximum or minimum point.
