MHB Determine the equation of the parabola
  • Thread starter Thread starter Azurin
    Parabola
To determine the equation of the parabola with a range of y|y≥-6 and x-intercepts at -5 and 3, the equation is expressed as y = k(x+5)(x-3), where k is a positive constant. The vertex is located at the midpoint of the x-intercepts, which is at x = -1. The y-coordinate of the vertex is -6, leading to the vertex coordinates of (-1, -6). By substituting these coordinates into the equation, the value of k can be calculated. The final equation of the parabola can then be established based on these findings.
Azurin
Determine the equation of the parabola with range y|y≧-6 and x-intercepts at -5 and 3.
Mathematics news on Phys.org
$y = k(x+5)(x-3)$, where $k$ is a constant
$y \ge -6 \implies k > 0$
vertex is located at $(x,-6)$ where $x$ is midway between the two x-intercepts
determine the x-value of the vertex, then use the vertex coordinates to determine the value of $k$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
