Determine the exponent(s) α>0 so f'(0) exists
  • Thread starter bhoom
In summary, it is not possible to determine a specific value for α that would make f'(0) defined. This is because the function involves x in the denominator multiple times, making it impossible to manipulate the equation to get rid of the denominators. It is also not possible to find an inverse or substitute values for x to solve for α. However, it can be concluded that α must be greater than 0 to ensure that the function is defined for all x.
bhoom
Determine α>0 so that f'(0) exists
[tex]f_{\alpha }(x)=|x|^{\alpha }sin\left (\frac{1}{x} \right ) , \left [x\neq 0, f_{\alpha }(x)=0 \right ][/tex]
I derived the function in two cases, one where x<0 and one x>0, and saw that we get x in a denominator three times, As I understand it, it does not matter what α is since f'(0), atm, is undefined. I tried to move around and see if I could get rid of the x`s, but I failed.
I also tried to see if I could substitute something(x=e^lnx), but again no luck.
I do not think it is possible to try to find an inverse in some way, since in the end I think that I would get stuck with some x in the denominator.
However, I'm still not sure how some α could fix the x`s in the denominators...
All in all I´m quite lost and have no idea how to find α or(if that's the case) show that α is irrelevant
when it comes to f'(0). The only answer I can think of is that α must be greater than 0 so that the function is defined for all x.
FAQ: Determine the exponent(s) α>0 so f'(0) exists
What is an exponent?
An exponent is a mathematical notation that represents the number of times a base number is multiplied by itself. It is written as a superscript to the right of the base number, such as 2^3, which means 2 is multiplied by itself 3 times (2 x 2 x 2 = 8).
What is the purpose of determining the exponent for f'(0) to exist?
The purpose of determining the exponent for f'(0) to exist is to ensure that the derivative of a function at x=0 is well-defined and has a finite value. This is important in many mathematical and scientific applications, as it allows us to understand the behavior and properties of a function at a specific point.
How is the exponent α determined?
The exponent α is determined by examining the limit of a function as it approaches x=0. If the limit exists and is finite, then the exponent α is the power of x in the function. For example, if the limit is 5 and the function is f(x) = x^5, then α=5.
What happens if the exponent α is negative?
If the exponent α is negative, then the function will approach infinity as x approaches 0. This means that the derivative at x=0 does not exist, as the function is not well-defined at that point. In order for f'(0) to exist, the exponent must be positive.
Can the exponent α be any positive value?
No, the exponent α must be a positive real number in order for f'(0) to exist. If the exponent is imaginary or complex, then the function will not be well-defined at x=0 and the derivative will not exist. However, in some cases, the exponent may be a rational number, such as 1/2 or 2/3, and the derivative can still exist at x=0.
