withoutname
- 5
- Homework Statement
- Determine the force with which the magnetic field of a coil acts on an infinitesimal cube of iron
- Relevant Equations
- F = q_0 v B don't work
Hi there,
I am working on a research paper and I need to determine the force with which the magnetic field of a coil acts on an small (pink-pong sized) iron ball. I tried to search for the force, acting of three dimensional object in magnetic field, but the only force I found was: F = q0vB
I read other similar posts in Physics Forums ( this, this and this) and PhysicsStackExchange, but I understand only that the force depends on how far is the object from the coil. I think, that if I know the force with which the magnetic field of a coil acts on an infinitesimal cube of iron, I can make some integrations and find the answer. So can someone say what is this force? I will be very thankful if You include sources from where I will be able to read about this force!
Thanks a lot!
Thanks a lot!
