Determine the horizontal distance travelled during its motion
In summary, a rock is projected from the edge of the top of a building with an initial velocity of 17.1 m/s at an angle of 37degrees above the horizontal. The rock strikes the ground a horizontal distance of 59.7 m from the base of the building. Assume that the ground is level and that the side of the building is vertical. The height of the building is then 34.202 m.
Ry122
565
A rock is projected from the edge of the top of a building with an initial velocity of 17.1 m/s at an angle of 37degrees above the horizontal. The rock strikes the ground a horizontal distance of 59.7 m from the base of the building. Assume that the ground is level and that the side of the building is vertical. How tall is the building?
My attempt:
This is the method i used to solve the problem:
1. I calculated the time to for the rock to carry out it's parabolic motion. To do this i just used v=u + at and u=17.1cos37 v=0 a=-9.8
t then was equal to 1.05. I multiplied this by two since a parabola is symmetric.
i then used this time to determine the horizontal distance traveled during its parabolic motion.
Then I subtracted this distance from the complete horizontal distance traveled which
gave me the horizontal distance traveled during its non parabolic flight.
This then allowed me to calculate the time of non-parabolic flight, which I then used
to calculate the vertical distance traveled during non-parabolic flight which would be equal to the height of the building.
The final answer I got was 34.202m which is incorrect. Can someone point out where I've gone wrong?
Thanks
This step is wrong.
What is the vertical component of initial velocity?
sorry, it should be sin, that was just an error in my typing, what i have in my calculations however is correct.
I don't understand what are you doing in this part... are you trying to solve the equation u+at = 0? if yes then what for?
im solving for t so that i can determine for what duration the rock is in the air while above the building so that i can then determine how long the rock is in the air below the building.
the time that the rock is in the air below the building for can then be used to determine how far the rock fell vertically while below the building hence determining the height of the building.
which gave me the horizontal distance traveled during its non parabolic flight...
Isn't the flight path after the projectile falls below its original trajectory point still parabolic?
I'm not 100% certain on that, maybe someone else can confirm...
Through out the motion it is projectile motion.
In this problem the range of the projectile, initial velocity and the angle of projection is given. From these values you can find the time flight.
Once you know the time of flight you can find the height of the building.
yeah it probably is still parabolic but that's not going to make my method of calculation incorrect in any way.
rl.bhat i did find the time of flight to determine the height of the building, but my final answer was incorrect.
can you please work the problem out and see if you get an answer different from mine?
Thanks
My answer is 48.65 m
That answer is correct.
Can you show me your working?
I am using the general equation of projectile.
Y = x*Voy/Vox -1/2*g*x^2/Vox^2
In this problem you have to take Y negative, because you are measuring it in the downward direction.
FAQ: Determine the horizontal distance travelled during its motion
What is the definition of "horizontal distance" in this context?
"Horizontal distance" refers to the distance travelled by an object in a straight line parallel to the ground, without taking into account any vertical movement.
How do you determine the horizontal distance travelled during an object's motion?
The horizontal distance travelled can be determined by measuring the displacement of the object from its starting point to its ending point along the horizontal axis. This can be done using a ruler, measuring tape, or by using mathematical equations such as the Pythagorean theorem.
Does the horizontal distance travelled depend on the speed of the object?
Yes, the horizontal distance travelled is directly influenced by the speed of the object. The faster the object is moving, the greater the horizontal distance travelled in a given amount of time.
Can the horizontal distance travelled be negative?
No, the horizontal distance travelled cannot be negative. It is a measure of the absolute distance covered by an object, and therefore, cannot have a negative value.
How is the horizontal distance travelled related to the time of motion?
The horizontal distance travelled is directly proportional to the time of motion. This means that as the time increases, the horizontal distance travelled by the object also increases. This relationship can be represented by the equation: distance = speed x time.
