Determine the magnitude of the contact force between the two blocks.
In summary, in this problem, there are two blocks of masses m1 and m2, with m1 > m2, placed on a frictionless, horizontal surface and a constant horizontal force is applied to m1. To find the magnitude of the acceleration, you can combine both masses and use the formula ƩF = ma. The contact force between the two blocks can be determined by using Newton's 3rd Law and creating a Free Body Diagram for each block. The force diagrams will show all the forces acting on each block, including the contact force labeled as P_21. By applying Newton's 2nd Law to the FBD, you can solve for the contact force. Frustration with understanding physics can be
AryRezvani
67
Two blocks of masses m1 and m2, with m1 > m2, are placed in contact with each other on a frictionless, horizontal surface. A constant horizontal force is applies to m1.
a) find the magnitude of the acceleration
b) determine the magnitude of the contact force between the two blocks.
ƩF =ma
Well, for a), because you are simply finding the magnitude of the acceleration of both particles, you can combine both masses and apply the above formula.
ƩF =(m1+m2)a
ax=F/(m1+m2).
Regarding b), I understand these particles need to be modeled individually, but how exactly would I do so.
My main issue is understanding the force diagrams drawn. Let's just say for example... M1.
M1 has mg acting upon it, and N pushing up. There is a force pushing the object to the right, but there is also a force labeled as P21. Could someone clear some of this up for me?
I don't even know anymore, so frustrated by the lack of teaching skill with this professor. Perhaps somebody could throw in some tips on understanding physics? -_-
ƩF =ma
An object will accelerate when a net force is exerted on it.
You have found the acceleration, you can find the force acting on it.
The contact force is the same on both sides as in Newton'n 3rd Law.
The use of Free Body Diagrams (FBD) is essential to the understanding and solution of forces acting on objects or particles. In a FBD, part of the system is isolated or separated from the rest of it, and then all forces acting on it, known and unknown, are identified and shown on the diagram, with their directions indicated where known. When the system is separated this way, forces that were internal to the system as a whole, become external forces on the FBD, and are shown in addition to any other external forces acting on the isolated part. When there is contact between objects, there is contact force acting on the object. That's what P_21 represents...the perpendicular or normal contact force of block 2 on block 1. Solve for it using Newton 2 applied to your FBD object.
Related to Determine the magnitude of the contact force between the two blocks.
1. What is the definition of contact force?
Contact force is the force that exists between two objects when they are in direct physical contact with each other. It is a type of force that is exerted by one object on the other due to their interaction.
2. How is the magnitude of contact force calculated?
The magnitude of contact force can be calculated by using the equation F = μN, where μ is the coefficient of friction between the two surfaces in contact and N is the normal force exerted by one object on the other.
3. What factors affect the magnitude of contact force?
The magnitude of contact force is influenced by several factors, including the coefficient of friction between the two surfaces, the normal force exerted, and the roughness or smoothness of the surfaces in contact. Other factors such as temperature and presence of lubricants can also impact the magnitude of contact force.
4. How does the angle of contact affect the magnitude of contact force?
The angle of contact between two surfaces affects the distribution of contact force. In general, a larger angle of contact results in a smaller magnitude of contact force, as the force is spread out over a larger area. On the other hand, a smaller angle of contact results in a larger magnitude of contact force.
5. Can the magnitude of contact force be negative?
No, the magnitude of contact force cannot be negative. It is always a positive value, as it represents the strength of the force between two objects in contact. However, the direction of the contact force can be negative if it is in the opposite direction of the motion or intended motion of an object.
