Determine the mean square error of a simple distribution
psie
Consider $$f_{X,Y}(x,y)=\begin{cases} c,&\text{for } x,y\geq0, x+y\leq 1,\\ 0,&\text{otherwise}.\end{cases},$$where ##c## is some constant to be determined. Determine ##E(Y\mid X=x)## and ##E(X\mid Y=y)##. Moreover, determine the expected quadratic prediction error ##E(Y-d(X))^2## for the best predictor ##d(X)## of ##Y## based on ##X##.
The best predictor is the conditional expectation, i.e. ##h(X)=E(Y\mid X)##.
What troubles me about this exercise is that I don't get the answer that the book gets regarding the expected quadratic prediction error.
##c## is determined by $$1=\int_0^1\int_0^{1-x} c\,dydx=c\int_0^1(1-x)\,dx=c\left[-\frac{(1-x)^2}{2}\right]_0^1=\frac{c}2,$$so ##c=2##. The marginal density of ##X## is $$f_X(x)=\int_0^{1-x}2\,dy=2(1-x),\quad 0<x<1.$$And the conditional one is $$f_{Y\mid X=x}(y)=\frac{f_{X,Y}(x,y)}{f_X(x)}=\frac2{2(1-x)}=\frac1{1-x},\quad 0<y<1-x.$$Finally, $$E(Y\mid X=x)=\int_0^{1-x}y\cdot\frac1{1-x}\,dy=\frac1{1-x}\left[\frac{y^2}{2}\right]_0^{1-x}=\frac{(1-x)^2}{2(1-x)}=\frac{1-x}{2}.$$ By symmetry, ##E(X\mid Y=y)=\frac{1-y}{2}##.
I am confident everything is correct up to this point, as this is actually an example in the book and done exactly the same way. But the next part is omitted in the book, i.e. determining the expected quadratic prediction error ##E(Y-E(Y\mid X))^2##, where ##E(Y\mid X)=(1-X)/2##. We can simplify as follows \begin{align*}E(Y-E(Y\mid X))^2&=E(Y-(1-X)/2)^2 \\ &=E(Y^2+(1-X)^2/4-Y(1-X)) \\ &=E\left(Y^2+\frac14-\frac{X}{2}+\frac{X^2}{4}-Y+YX\right).\end{align*} Since ##X,Y## have the exact same distribution, we can replace ##Y## with ##X## except in the last term I believe, i.e. except in ##YX##. So we have $$E\left(\frac{5X^2}{4}+\frac14-\frac{3X}{2}+YX\right)=\frac54E(X^2)+\frac14-\frac32E(X)+E(YX).$$ I used WolframAlpha to compute the three expectations on the right-hand side of this last equation:
##E(X)=\frac13##: first integral
##E(X^2)=\frac16##: second integral
##E(XY)=\frac1{12}##: third integral
Therefor $$E(Y-(1-X)/2)^2 =\frac54\cdot\frac16+\frac14-\frac32\cdot\frac13+\frac1{12}=\frac1{24}.$$The book gets ##\frac1{48}##.
Likes Gavran and docnet
I have tried the calculation a couple of different ways, and get the same answer as you. I suspect they may have forgotten (as I almost did) to include the constant c in the calculation.
Your result is correct.
The conditional probability distribution of Y given X is a continuous uniform distribution. You can check the result by using the next expression $$ E((Y-E(Y|X))^2) = E(Var(Y|X)) $$ and by using the formula for calculating a variance of a continuous uniform distribution.
I assume the " Best predictor" is some estimator. But then what would " best" mean here, as there are estimators that may have, e.g. , minimal variance, be consistent, etc.
Here we are talking about the predictor of ## Y ## based on ## X ## with the lowest mean squared error among all possible estimators of ## Y ## based on ## X ##.
