Determine the nearest neighbour equilibrium distance
In summary, we discussed the energy per atom for argon crystal and how to determine the nearest neighbour equilibrium distance, as well as the contributions of van der Waals and repulsion between cores to the total energy. We also estimated the magnitude of the van der Waals force between two argon atoms at equilibrium distance.
didy
Can teach me homework to do?
2. Energy per atom for argon crystal is given by
U(R) = −(A /R6 )+ (B/R12 )
where A = 1.03 ×10−77 Jm6 and B = 1.62 ×10−134 Jm12 are constants and R is the nearest
neighbour distance.
(a) Explain both expressions on the right hand side in the above equation.
(b) Determine the nearest neighbour equilibrium distance.
(c) Compare the van der Waals and repulsion between cores contributions to the energy at
the equilibrium distance.
(d) Estimate the magnitude of the van der Waals force between 2 argon atoms at
equilibrium distance, assuming that the van der Waals energy is only due to the nearest
neighbour interaction.
Thanks a lot...
Sure, I would be happy to help you with your homework on argon crystal energy per atom.
(a) The first expression, -(A/R6), represents the van der Waals attraction between two argon atoms. This attraction is due to the temporary dipoles that form between atoms, creating a weak attractive force. The second expression, (B/R12), represents the repulsion between the two atoms due to their electron clouds overlapping. This repulsion is much stronger than the van der Waals attraction and is due to the Pauli exclusion principle, which states that no two electrons can occupy the same space.
(b) To determine the nearest neighbour equilibrium distance, we need to find the distance at which the energy is at its minimum. This can be done by taking the derivative of the energy equation with respect to R and setting it equal to 0. Solving for R gives us the equilibrium distance of R = (2B/A)^(1/6) = 3.71 x 10^-10 m.
(c) At the equilibrium distance, the van der Waals energy is equal to -(A/R6) = -2.05 x 10^-4 J. The repulsion between cores energy is equal to (B/R12) = 1.48 x 10^-4 J. This means that the repulsion between cores contributes more to the total energy than the van der Waals attraction.
(d) To estimate the magnitude of the van der Waals force between two argon atoms at equilibrium distance, we can use the force equation F = -dU/dR = 6A/R7 = 3.61 x 10^-8 N. This is a very weak force, but it is still strong enough to keep the atoms bonded together in a crystal structure.
I hope this helps you understand the energy per atom for argon crystal and how to determine the nearest neighbour equilibrium distance. Let me know if you have any other questions or need further clarification. Good luck with your homework!
FAQ: Determine the nearest neighbour equilibrium distance
1. What is the nearest neighbour equilibrium distance?
The nearest neighbour equilibrium distance is the distance at which the forces of attraction and repulsion between atoms or molecules are balanced, resulting in the most stable arrangement of particles.
2. How is the nearest neighbour equilibrium distance determined?
The nearest neighbour equilibrium distance is determined through experimental methods, such as X-ray crystallography or spectroscopy, or through theoretical calculations using mathematical models and equations.
3. Why is the nearest neighbour equilibrium distance important?
The nearest neighbour equilibrium distance is important because it provides information about the bonding and structure of a material, which can have significant impacts on its properties and behavior.
4. Can the nearest neighbour equilibrium distance change?
Yes, the nearest neighbour equilibrium distance can change depending on factors such as temperature, pressure, and chemical reactions. It can also vary between different materials.
5. How does the nearest neighbour equilibrium distance affect the physical properties of a material?
The nearest neighbour equilibrium distance can affect a material's density, melting point, hardness, and other physical properties. It can also influence its electrical and magnetic properties, as well as its ability to conduct heat and sound.
